D-Jet ECU Idle Mixture screw CCW to idle |
Morrie |
Sep 11 2017, 03:18 PM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
Let me start with saying I need to go through the system in more detail soon. I am collecting vacuum hoses, will get injectors tested, and so on.
Meanwhile, the car runs very fast and strong. The two symptoms I have are odd, and seem contradictory to me. First, the car wants to idle high when warm. I can adjust that out mostly with the idle speed screw on the throttle body, but there is a tipping point there where the idle speed becomes very sensitive, up to that point large changes in screw setting do little to nothing. Second, the ECU idle mixture screw needs to be full CCW to idle. If I move the setting off of full CCW it starts to stall and die. Third, maybe unrelated, is a puff of blackish smoke on decel. (is that over run?). Not sure if this is related, or just some wear showing. The car runs smooth and strong under throttle, will smoke the tires off the line if asked, and starts easily both cold and warm. It actually does run pretty well with the above considered, but it doesn't seem like these conditions are normal. Still a learner on D-Jet here, reading and understanding as I go... Having fun, not frustrated. Thanks guys! Morrie |
BeatNavy |
Sep 12 2017, 09:00 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Awesome, all good steps to take. D-Jet can be simple to troubleshoot - unless more than one thing is wrong (which is often the case, especially for those souls trying to revive a car that hasn't been given TLC in a long while). That WB 02 will help definitively answer at least one question. If you get info that validates running rich, make sure to check your MPS as a possible suspect, too.
Good luck! |
Lo-Fi Version | Time is now: 10th June 2024 - 08:16 AM |
