dizzy rebuild, anyone done one? |
qa1142 |
Nov 3 2004, 08:52 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
I would like to replace the bushings / bearings.
Anyone done this? Doesn't seam like it will be hard... will it? |
Cap'n Krusty |
Nov 3 2004, 01:40 PM
The vacuum can alone costs me MORE, as a shop, than the whole POS distributor from a FLAPS! Don't do it! They're put together with the most gyppo of parts, and aren't even curved to spec unless you're VERY lucky. I have the bushings, but they're hardly ever bad. Gey a vacuum can, a breaker plate, a set of trigger points, and clean it up real good. Lube it where it needs it, using the right oils and grease, and let 'er rip! Expensive, but worth it in the end, and you don't necessarily need toe businngs and tools. BTW, the bushings are NOT available from Bosch, Porsche, or VW. Never have been ................ The Cap'n
Lo-Fi Version | Time is now: 11th June 2024 - 03:46 AM |
