| BRAVE_HELIOS |
Sep 18 2017, 05:06 PM
"Knowledge speaks, wisdom listens" ![]() ![]() Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
I think I have pretty much exhausted the ways to make a mechanical Chrysler/Renegade water pump setup run as efficiently as possible.
At this time; I do notice that at idle, the engine temp creeps up but as soon as I give it throttle; the temp comes down by almost 10 degrees... it stands the reason since at higher rpm's, there is more water flow. Now for the ideas... I have a spare aux electric water pump from my 545i. BMW uses the pump to assist in pumping coolant to the heater core. It is a small unit and I am sure the flow is low compared to the standard electric or mechanical water pump. Could I integrate this lil ol electric unit to flow a more consistent rate, even at idle? Would it interrupt the flow from the mechanical w/p? The other item is the oil cooler that came with the engine but I have yet to install. Would this help cool the engine down and by how much? |
| Mike1981 |
Sep 19 2017, 01:57 PM
Member ![]() ![]() Group: Members Posts: 265 Joined: 21-July 14 From: Phoenix Member No.: 17,663 Region Association: South East States |
Hello
I am no expert but I have owbed 2 V8 conversions. the 1st has a Mopar water pump I tried to get the air out but felt it never was able to adequately cool the engine especially in the summer the engine overheated on me once. The one I have now has an electric water pump Cool as a cucumber even driving it 13 hours straight. Hope this helps MIke |
BRAVE_HELIOS V8 cooling ideas. Sep 18 2017, 05:06 PM
HalfMoon
I think I have pretty much exhausted the ways to ... Sep 18 2017, 05:50 PM
DM_2000 What specifically are you using for an engine and ... Sep 18 2017, 06:03 PM
BRAVE_HELIOS
What specifically are you using for an engine and... Sep 19 2017, 12:18 PM
Andyrew I would certainly entertain a oil cooler at this p... Sep 18 2017, 09:29 PM
BRAVE_HELIOS
I would certainly entertain a oil cooler at this ... Sep 19 2017, 12:11 PM
Andyrew The oil cooler will help for sure. Start with that... Sep 19 2017, 12:32 PM
burton73 Tony,
I do not know how long you have been marrie... Sep 19 2017, 02:19 PM
BRAVE_HELIOS
Tony,
I do not know how long you have been marri... Sep 20 2017, 08:19 AM
mgp4591
Tony,
I do not know how long you have been marr... Sep 20 2017, 04:00 PM
DM_2000 Here is a pic of the aux pump across the upper rad... Sep 19 2017, 07:07 PM
cali914 ron Davis radiator with 2 spal fans that is what ... Sep 19 2017, 09:38 PM
BRAVE_HELIOS
ron Davis radiator with 2 spal fans that is what... Sep 20 2017, 08:38 AM
cali914
ron Davis radiator with 2 spal fans that is wha... Sep 20 2017, 06:18 PM
BRAVE_HELIOS
[quote name='BRAVE_HELIOS' post='2529542' date='S... Sep 21 2017, 08:40 AM
BRAVE_HELIOS
[quote name='BRAVE_HELIOS' post='2529542' date='... Sep 21 2017, 11:28 AM
Andyrew
[quote name='cali914' post='2529711' date='Sep 20... Sep 21 2017, 12:14 PM
BRAVE_HELIOS
[quote name='cali914' post='2529711' date='Sep 2... Sep 22 2017, 04:37 PM
cali914 I am using same radiator in my v6 honda 914 as i d... Sep 20 2017, 06:20 PM
BRAVE_HELIOS
I am using same radiator in my v6 honda 914 as i ... Sep 21 2017, 08:36 AM
914GT Best location for a remote electric water pump is ... Sep 21 2017, 08:52 AM
BRAVE_HELIOS I wanted to give an update on how I DRASTICALLY im... Oct 18 2017, 07:26 PM
cali914 What are your temps now ideling freeway and drivin... Oct 19 2017, 08:20 AM
BRAVE_HELIOS
What are your temps now ideling freeway and drivi... Oct 19 2017, 09:29 AM
DM_2000 I'd put some muffin fans under the cooler blow... Oct 19 2017, 05:06 PM
BRAVE_HELIOS
I'd put some muffin fans under the cooler blo... Oct 24 2017, 10:50 AM
BRAVE_HELIOS
I'd put some muffin fans under the cooler blo... Oct 24 2017, 11:19 AM
DM_2000 I'd probably fit 2 maybe 3 fans. Find a fan t... Oct 24 2017, 04:53 PM
76-914 Man, your cooling system is getting complicated. I... Oct 24 2017, 05:01 PM
BRAVE_HELIOS
Man, your cooling system is getting complicated. ... Oct 24 2017, 05:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:35 AM |
