> V8 cooling ideas., Only because I have the parts!
BRAVE_HELIOS
post Sep 18 2017, 05:06 PM
"Knowledge speaks, wisdom listens"
I think I have pretty much exhausted the ways to make a mechanical Chrysler/Renegade water pump setup run as efficiently as possible.
At this time; I do notice that at idle, the engine temp creeps up but as soon as I give it throttle; the temp comes down by almost 10 degrees... it stands the reason since at higher rpm's, there is more water flow.
Now for the ideas... I have a spare aux electric water pump from my 545i. BMW uses the pump to assist in pumping coolant to the heater core. It is a small unit and I am sure the flow is low compared to the standard electric or mechanical water pump. Could I integrate this lil ol electric unit to flow a more consistent rate, even at idle? Would it interrupt the flow from the mechanical w/p?
The other item is the oil cooler that came with the engine but I have yet to install. Would this help cool the engine down and by how much?
cali914
post Sep 19 2017, 09:38 PM
cali914
ron Davis radiator with 2 spal fans that is what keeps it cool i tried 5 different pumps and 5 different radiators after shelling out the bucks for the Renegade radiator and fans which is really ron davis dual pass all aluminum and two big fans my v8 small block 427 stayed between 180 and 205 all day long. Oh i was using the Meziere 55gpm electric water pump located at the bottom of the radiator.
BRAVE_HELIOS   V8 cooling ideas.   Sep 18 2017, 05:06 PM
HalfMoon   I think I have pretty much exhausted the ways to ...   Sep 18 2017, 05:50 PM
DM_2000   What specifically are you using for an engine and ...   Sep 18 2017, 06:03 PM
BRAVE_HELIOS   What specifically are you using for an engine and...   Sep 19 2017, 12:18 PM
Andyrew   I would certainly entertain a oil cooler at this p...   Sep 18 2017, 09:29 PM
BRAVE_HELIOS   I would certainly entertain a oil cooler at this ...   Sep 19 2017, 12:11 PM
Andyrew   The oil cooler will help for sure. Start with that...   Sep 19 2017, 12:32 PM
Mike1981   Hello I am no expert but I have owbed 2 V8 conver...   Sep 19 2017, 01:57 PM
burton73   Tony, I do not know how long you have been marrie...   Sep 19 2017, 02:19 PM
BRAVE_HELIOS   Tony, I do not know how long you have been marri...   Sep 20 2017, 08:19 AM
mgp4591   Tony, I do not know how long you have been marr...   Sep 20 2017, 04:00 PM
DM_2000   Here is a pic of the aux pump across the upper rad...   Sep 19 2017, 07:07 PM
cali914   ron Davis radiator with 2 spal fans that is what ...   Sep 19 2017, 09:38 PM
BRAVE_HELIOS   ron Davis radiator with 2 spal fans that is what...   Sep 20 2017, 08:38 AM
cali914   ron Davis radiator with 2 spal fans that is wha...   Sep 20 2017, 06:18 PM
BRAVE_HELIOS   [quote name='BRAVE_HELIOS' post='2529542' date='S...   Sep 21 2017, 08:40 AM
BRAVE_HELIOS   [quote name='BRAVE_HELIOS' post='2529542' date='...   Sep 21 2017, 11:28 AM
Andyrew   [quote name='cali914' post='2529711' date='Sep 20...   Sep 21 2017, 12:14 PM
BRAVE_HELIOS   [quote name='cali914' post='2529711' date='Sep 2...   Sep 22 2017, 04:37 PM
cali914   I am using same radiator in my v6 honda 914 as i d...   Sep 20 2017, 06:20 PM
BRAVE_HELIOS   I am using same radiator in my v6 honda 914 as i ...   Sep 21 2017, 08:36 AM
914GT   Best location for a remote electric water pump is ...   Sep 21 2017, 08:52 AM
BRAVE_HELIOS   I wanted to give an update on how I DRASTICALLY im...   Oct 18 2017, 07:26 PM
cali914   What are your temps now ideling freeway and drivin...   Oct 19 2017, 08:20 AM
BRAVE_HELIOS   What are your temps now ideling freeway and drivi...   Oct 19 2017, 09:29 AM
DM_2000   I'd put some muffin fans under the cooler blow...   Oct 19 2017, 05:06 PM
BRAVE_HELIOS   I'd put some muffin fans under the cooler blo...   Oct 24 2017, 10:50 AM
BRAVE_HELIOS   I'd put some muffin fans under the cooler blo...   Oct 24 2017, 11:19 AM
DM_2000   I'd probably fit 2 maybe 3 fans. Find a fan t...   Oct 24 2017, 04:53 PM
76-914   Man, your cooling system is getting complicated. I...   Oct 24 2017, 05:01 PM
BRAVE_HELIOS   Man, your cooling system is getting complicated. ...   Oct 24 2017, 05:14 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:35 AM
