turning tail shifter into a sidewinder: sources for bushings?, Have I been mislead? |
Calwaterbear |
Sep 19 2017, 08:59 PM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
Ok guys, have a 72, with the tailshifter. so I salvaged everything from a junked 74 - from the shifter to the transmission.
so first - i have been told that you just need to change the linkages, but in reading on the Pelican, they indicate you would need the newer transmission as well - IE no conversion, it is a replacement - trans and shifter. Can anyone confirm that? my hope/plan is to leave the current trans in the 72, and turn it into a sidewinder. so took all the shift rods etc, wire wheeled em, hit em with primer and an enamel for longevity and rust protection. So I guess next step is to replace all the bushings, Right? so anyone have a favorite supplier? does 914 rubber carry em? I assume pelican does. I'm hoping they come as a kit! somebodty needs to lie to me and tell me this is a simple straightforward conversion, slap it back in, 2 hours tops! |
Calwaterbear |
Sep 20 2017, 01:52 PM
If I am reading this correctly, and following the other threads, it looks like I may temporarily be - shall we say screwed. While I have all the shifter and linkage parts, and even the side mount transmission, i did not harvest the engine mount bar - because the donor was a failed engine swap, and that part was missing. so it looks like i am short the mounting bar, some of the bushings to mount the bar, some braketry, and a piece of engine tin.
So for now, I'll probably try and refresh the tail mount, and keep looking for the rest of the pieces, so I can eventually do the swap |
Lo-Fi Version | Time is now: 10th June 2024 - 11:47 PM |
