> V8 cooling ideas., Only because I have the parts!
BRAVE_HELIOS
post Sep 18 2017, 05:06 PM
"Knowledge speaks, wisdom listens"
I think I have pretty much exhausted the ways to make a mechanical Chrysler/Renegade water pump setup run as efficiently as possible.
At this time; I do notice that at idle, the engine temp creeps up but as soon as I give it throttle; the temp comes down by almost 10 degrees... it stands the reason since at higher rpm's, there is more water flow.
Now for the ideas... I have a spare aux electric water pump from my 545i. BMW uses the pump to assist in pumping coolant to the heater core. It is a small unit and I am sure the flow is low compared to the standard electric or mechanical water pump. Could I integrate this lil ol electric unit to flow a more consistent rate, even at idle? Would it interrupt the flow from the mechanical w/p?
The other item is the oil cooler that came with the engine but I have yet to install. Would this help cool the engine down and by how much?
cali914
post Sep 20 2017, 06:20 PM
cali914
I am using same radiator in my v6 honda 914 as i did with the v8 only difference is i am using honda stock water pump 180 degree all day long.
BRAVE_HELIOS   V8 cooling ideas.   Sep 18 2017, 05:06 PM
HalfMoon   I think I have pretty much exhausted the ways to ...   Sep 18 2017, 05:50 PM
DM_2000   What specifically are you using for an engine and ...   Sep 18 2017, 06:03 PM
BRAVE_HELIOS   What specifically are you using for an engine and...   Sep 19 2017, 12:18 PM
Andyrew   I would certainly entertain a oil cooler at this p...   Sep 18 2017, 09:29 PM
BRAVE_HELIOS   I would certainly entertain a oil cooler at this ...   Sep 19 2017, 12:11 PM
Andyrew   The oil cooler will help for sure. Start with that...   Sep 19 2017, 12:32 PM
Mike1981   Hello I am no expert but I have owbed 2 V8 conver...   Sep 19 2017, 01:57 PM
burton73   Tony, I do not know how long you have been marrie...   Sep 19 2017, 02:19 PM
BRAVE_HELIOS   Tony, I do not know how long you have been marri...   Sep 20 2017, 08:19 AM
mgp4591   Tony, I do not know how long you have been marr...   Sep 20 2017, 04:00 PM
DM_2000   Here is a pic of the aux pump across the upper rad...   Sep 19 2017, 07:07 PM
cali914   ron Davis radiator with 2 spal fans that is what ...   Sep 19 2017, 09:38 PM
BRAVE_HELIOS   ron Davis radiator with 2 spal fans that is what...   Sep 20 2017, 08:38 AM
cali914   ron Davis radiator with 2 spal fans that is wha...   Sep 20 2017, 06:18 PM
BRAVE_HELIOS   [quote name='BRAVE_HELIOS' post='2529542' date='S...   Sep 21 2017, 08:40 AM
BRAVE_HELIOS   [quote name='BRAVE_HELIOS' post='2529542' date='...   Sep 21 2017, 11:28 AM
Andyrew   [quote name='cali914' post='2529711' date='Sep 20...   Sep 21 2017, 12:14 PM
BRAVE_HELIOS   [quote name='cali914' post='2529711' date='Sep 2...   Sep 22 2017, 04:37 PM
cali914   I am using same radiator in my v6 honda 914 as i d...   Sep 20 2017, 06:20 PM
BRAVE_HELIOS   I am using same radiator in my v6 honda 914 as i ...   Sep 21 2017, 08:36 AM
914GT   Best location for a remote electric water pump is ...   Sep 21 2017, 08:52 AM
BRAVE_HELIOS   I wanted to give an update on how I DRASTICALLY im...   Oct 18 2017, 07:26 PM
cali914   What are your temps now ideling freeway and drivin...   Oct 19 2017, 08:20 AM
BRAVE_HELIOS   What are your temps now ideling freeway and drivi...   Oct 19 2017, 09:29 AM
DM_2000   I'd put some muffin fans under the cooler blow...   Oct 19 2017, 05:06 PM
BRAVE_HELIOS   I'd put some muffin fans under the cooler blo...   Oct 24 2017, 10:50 AM
BRAVE_HELIOS   I'd put some muffin fans under the cooler blo...   Oct 24 2017, 11:19 AM
DM_2000   I'd probably fit 2 maybe 3 fans. Find a fan t...   Oct 24 2017, 04:53 PM
76-914   Man, your cooling system is getting complicated. I...   Oct 24 2017, 05:01 PM
BRAVE_HELIOS   Man, your cooling system is getting complicated. ...   Oct 24 2017, 05:14 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:34 AM
