| BRAVE_HELIOS |
Sep 18 2017, 05:06 PM
"Knowledge speaks, wisdom listens" ![]() ![]() Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
I think I have pretty much exhausted the ways to make a mechanical Chrysler/Renegade water pump setup run as efficiently as possible.
At this time; I do notice that at idle, the engine temp creeps up but as soon as I give it throttle; the temp comes down by almost 10 degrees... it stands the reason since at higher rpm's, there is more water flow. Now for the ideas... I have a spare aux electric water pump from my 545i. BMW uses the pump to assist in pumping coolant to the heater core. It is a small unit and I am sure the flow is low compared to the standard electric or mechanical water pump. Could I integrate this lil ol electric unit to flow a more consistent rate, even at idle? Would it interrupt the flow from the mechanical w/p? The other item is the oil cooler that came with the engine but I have yet to install. Would this help cool the engine down and by how much? |
| cali914 |
Sep 19 2017, 09:38 PM
cali914 ![]() ![]() Group: Members Posts: 458 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
ron Davis radiator with 2 spal fans that is what keeps it cool i tried 5 different pumps and 5 different radiators after shelling out the bucks for the Renegade radiator and fans which is really ron davis dual pass all aluminum and two big fans my v8 small block 427 stayed between 180 and 205 all day long. Oh i was using the Meziere 55gpm electric water pump located at the bottom of the radiator.
| BRAVE_HELIOS |
Sep 20 2017, 08:38 AM
ron Davis radiator with 2 spal fans that is what keeps it cool i tried 5 different pumps and 5 different radiators after shelling out the bucks for the Renegade radiator and fans which is really ron davis dual pass all aluminum and two big fans my v8 small block 427 stayed between 180 and 205 all day long. Oh i was using the Meziere 55gpm electric water pump located at the bottom of the radiator. Is your radiator a 2-core, dual pass unit? If you pump was located at the bottom of the radiator, does that mean it was pushing coolant from that location to the engine (lines out of lower rad to water pump then out of water pump to engine block)? |
| cali914 |
Sep 20 2017, 06:18 PM
ron Davis radiator with 2 spal fans that is what keeps it cool i tried 5 different pumps and 5 different radiators after shelling out the bucks for the Renegade radiator and fans which is really ron davis dual pass all aluminum and two big fans my v8 small block 427 stayed between 180 and 205 all day long. Oh i was using the Meziere 55gpm electric water pump located at the bottom of the radiator. Is your radiator a 2-core, dual pass unit? If you pump was located at the bottom of the radiator, does that mean it was pushing coolant from that location to the engine (lines out of lower rad to water pump then out of water pump to engine block)? Yes it was pushing but i figured if it was at the lowest point in the system it could never starve for water. If you fill the system from the highest point and you have a good reservoir it will self bleed itself as it contracts and expands pushing air out and sucking water back from overflow tank. |
| BRAVE_HELIOS |
Sep 21 2017, 08:40 AM
ron Davis radiator with 2 spal fans that is what keeps it cool i tried 5 different pumps and 5 different radiators after shelling out the bucks for the Renegade radiator and fans which is really ron davis dual pass all aluminum and two big fans my v8 small block 427 stayed between 180 and 205 all day long. Oh i was using the Meziere 55gpm electric water pump located at the bottom of the radiator. Is your radiator a 2-core, dual pass unit? If you pump was located at the bottom of the radiator, does that mean it was pushing coolant from that location to the engine (lines out of lower rad to water pump then out of water pump to engine block)? Yes it was pushing but i figured if it was at the lowest point in the system it could never starve for water. If you fill the system from the highest point and you have a good reservoir it will self bleed itself as it contracts and expands pushing air out and sucking water back from overflow tank. I was not sure if there is a preferred placement... front or rear, bottom or top of the car. I am looking at the Jegs 50 gpm unit that is designed to fit in a stock BB Mopar w/p enclosure/case which therefore; theoretically should fit in the Renegade w/p enclosure; perhaps with a bit of modifying. |
| Andyrew |
Sep 21 2017, 12:14 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
ron Davis radiator with 2 spal fans that is what keeps it cool i tried 5 different pumps and 5 different radiators after shelling out the bucks for the Renegade radiator and fans which is really ron davis dual pass all aluminum and two big fans my v8 small block 427 stayed between 180 and 205 all day long. Oh i was using the Meziere 55gpm electric water pump located at the bottom of the radiator. Is your radiator a 2-core, dual pass unit? If you pump was located at the bottom of the radiator, does that mean it was pushing coolant from that location to the engine (lines out of lower rad to water pump then out of water pump to engine block)? Yes it was pushing but i figured if it was at the lowest point in the system it could never starve for water. If you fill the system from the highest point and you have a good reservoir it will self bleed itself as it contracts and expands pushing air out and sucking water back from overflow tank. I was not sure if there is a preferred placement... front or rear, bottom or top of the car. I am looking at the Jegs 50 gpm unit that is designed to fit in a stock BB Mopar w/p enclosure/case which therefore; theoretically should fit in the Renegade w/p enclosure; perhaps with a bit of modifying. I cant recommend enough (apparently) a water pump controller that will actually control the speed of the pump. If you just get a pump that will go on and off you'll find that it will overcool causing getting up to temp to take forever. This is what I recommend. Read into how the LCD controller works. http://www.ebay.com/itm/Davies-Craig-DC-89...0JL&vxp=mtr Another option if you dont need an LCD (I love mine though, being able to see what is going on). This one does essentially the same thing. http://www.ebay.com/itm/Davies-Craig-EWP15...ciR&vxp=mtr |
BRAVE_HELIOS V8 cooling ideas. Sep 18 2017, 05:06 PM
HalfMoon
I think I have pretty much exhausted the ways to ... Sep 18 2017, 05:50 PM
DM_2000 What specifically are you using for an engine and ... Sep 18 2017, 06:03 PM
BRAVE_HELIOS
What specifically are you using for an engine and... Sep 19 2017, 12:18 PM
Andyrew I would certainly entertain a oil cooler at this p... Sep 18 2017, 09:29 PM
BRAVE_HELIOS
I would certainly entertain a oil cooler at this ... Sep 19 2017, 12:11 PM
Andyrew The oil cooler will help for sure. Start with that... Sep 19 2017, 12:32 PM
Mike1981 Hello
I am no expert but I have owbed 2 V8 conver... Sep 19 2017, 01:57 PM
burton73 Tony,
I do not know how long you have been marrie... Sep 19 2017, 02:19 PM
BRAVE_HELIOS
Tony,
I do not know how long you have been marri... Sep 20 2017, 08:19 AM
mgp4591
Tony,
I do not know how long you have been marr... Sep 20 2017, 04:00 PM
DM_2000 Here is a pic of the aux pump across the upper rad... Sep 19 2017, 07:07 PM
BRAVE_HELIOS
[quote name='BRAVE_HELIOS' post='2529542' date='... Sep 21 2017, 11:28 AM
BRAVE_HELIOS
[quote name='cali914' post='2529711' date='Sep 2... Sep 22 2017, 04:37 PM
cali914 I am using same radiator in my v6 honda 914 as i d... Sep 20 2017, 06:20 PM
BRAVE_HELIOS
I am using same radiator in my v6 honda 914 as i ... Sep 21 2017, 08:36 AM
914GT Best location for a remote electric water pump is ... Sep 21 2017, 08:52 AM
BRAVE_HELIOS I wanted to give an update on how I DRASTICALLY im... Oct 18 2017, 07:26 PM
cali914 What are your temps now ideling freeway and drivin... Oct 19 2017, 08:20 AM
BRAVE_HELIOS
What are your temps now ideling freeway and drivi... Oct 19 2017, 09:29 AM
DM_2000 I'd put some muffin fans under the cooler blow... Oct 19 2017, 05:06 PM
BRAVE_HELIOS
I'd put some muffin fans under the cooler blo... Oct 24 2017, 10:50 AM
BRAVE_HELIOS
I'd put some muffin fans under the cooler blo... Oct 24 2017, 11:19 AM
DM_2000 I'd probably fit 2 maybe 3 fans. Find a fan t... Oct 24 2017, 04:53 PM
76-914 Man, your cooling system is getting complicated. I... Oct 24 2017, 05:01 PM
BRAVE_HELIOS
Man, your cooling system is getting complicated. ... Oct 24 2017, 05:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:35 AM |
