> Passenger side inside door handle?, How do you remove it?
Calwaterbear
post Sep 22 2017, 05:12 PM
alright guys, need to pull the door card from the door. To do so, as far as I can tell, you need to pull the inside door handle - at least the "dish?
on the drivers side the door handle is secured with 2c bolts going into welded in nuts inside the door, but is it the same on the passemnger side? and if so, how do you get to them?
thanks in advance
914 RZ-1
post Sep 22 2017, 05:30 PM
Porsche Padawan
It works the same on both sides:
Pry out the plastic cover with a screw driver. There is a screw under it near the handle. You'll have to pull out the door handle like you are opening the door to get to it. Unscrew that and the escutcheon (frame) will come off.
- Lo-Fi Version Time is now: 6th July 2025 - 10:23 AM
