Bus and 914 engine difference |
cal44 |
Sep 24 2017, 11:37 AM
Member Group: Members Posts: 165 Joined: 8-October 09 From: Encinitas, Ca. Member No.: 10,910 Region Association: Southwest Region |
Lads,
Not being fully versed on everything VW, I was curious if the a 2.0 Bus engine and a 2.0 914 engine are the same......Or, will a Bus 2.0 bolt right into a 914. Air cooled of course. Also 1.7 and 1.8 while you are at it. Thanks bunch. Mike Sarcastic remarks welcome, I like the humor |
barefoot |
Sep 25 2017, 07:40 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
When i got my 76, it had already been few at least one engine rebuild, it was a correct 2.0L GC code block but was equipped with 022-101-372G bus heads with smaller 48cc chambers. Later I acquired a GA code 2.0L motor with the proper 039-101-371A large valve heads but has larger 60cc chambers.
If you want high compression and smaller valve sizes, the bus heads will do that for you |
Lo-Fi Version | Time is now: 1st June 2024 - 06:46 PM |
