> Generator Light, Is On
EdwardBlume
post May 18 2017, 12:25 PM
Was driving last week and the generator light came on, went off, came on again, and then it stayed on.
Belt is on, VR was swapped with another I have around (and another is on the way), ground at the tranny is connected and good, battery charged and tightened, fuses 8 & 9 are good and new, spun to make sure they are connected.
Voltage meter is showing 12 to 13.
Anything else I can troubleshoot before I pull the generator? (IMG:style_emoticons/default/dry.gif)
Spoke
post Sep 28 2017, 06:25 PM
Jerry
Rob,
Copying my PM to you with additional info:
Since you've changed the alternator, VR, and battery, I have questions about the operation.
Do you measure those numbers right after starting the car or after a bit of driving? Does the light go out or on dimly?
With all new components, it may be some of the wiring at issue. Don't think it's a short. May be a corroded or oxidized connection somewhere.
Does the light go out when the engine speed is elevated to 2k RPM or above?
On the wire going from the alternator to the VR, measure the voltage on the RED wire to chassis and BROWN wire to chassis. The RED wire is the wire going to the GEN light. Just checking if there's some voltage drop from the VR to the GEN light. The BROWN wire is alternator ground. Just checking to make sure the engine/alternator is grounded.
What voltage do you measure on the battery? Measure this from battery post to chassis ground.
When the engine speed is elevated to 2k RPM, what do you measure on the battery?
What is the condition of the transmission ground strap? Have you cleaned/checked the connections?
What is the condition of the battery ground strap? Have you cleaned/checked the connections?
Any bit of oxidation or corroded wires/connections can cause huge problems for the charging system.
EdwardBlume
post Sep 28 2017, 09:13 PM
QUOTE(Spoke @ Sep 28 2017, 05:25 PM) *
Rob,
A: At startup, a few revs and measured at idle. The light never goes out. Months ago it came on while driving. Went off for a little bit on the way home, and then stayed on. Been on ever since.
A: From what I can tell, the blue wire joins the harness off the relay board. So you may be right about corrosion or the board perhaps?
A: No
A: Its a new harness.
A: Will check again tomorrow.
A: Volt gauge moves up on revs so the alt is working. I can test that tomorrow.
A: Visually. I'll pull it tomorrow.
A: Visually. Will pull it tomorrow.
A: I installed a new harness so I know everything is working up to the relay board.
Thanks Spoke. We'll get this! I appreciate your help with Dad's car.
Edward Blume   Generator Light   May 18 2017, 12:25 PM
Edward Blume   And its running fine.....   May 18 2017, 12:26 PM
BillC   Check the voltage at the battery using a DVOM. Sh...   May 18 2017, 12:35 PM
Elliot Cannon   Check the voltage at the battery with the engine r...   May 18 2017, 12:35 PM
Edward Blume   Thanks guys. The battery is coming through at 12.2...   May 18 2017, 12:51 PM
porschetub   IF the voltage is higher when running you have cha...   May 18 2017, 02:16 PM
Edward Blume   IF the voltage is higher when running you have ch...   May 18 2017, 03:50 PM
Elliot Cannon   IF the voltage is higher when running you have c...   May 18 2017, 07:40 PM
Edward Blume   New alternator, battery, and voltage regulator. St...   Jun 21 2017, 07:06 PM
porschetub   New alternator, battery, and voltage regulator. S...   Jun 21 2017, 11:26 PM
Kansas 914   You don't have an LED in the gauge do you?   Jun 22 2017, 06:34 AM
Edward Blume   You don't have an LED in the gauge do you? N...   Jun 22 2017, 10:45 AM
Spoke   New alternator, battery, and voltage regulator. S...   Jun 23 2017, 07:40 PM
Krieger   Test the wire after the vr back to the light. Is ...   Jun 22 2017, 07:57 AM
Edward Blume   Test the wire after the vr back to the light. Is...   Jun 22 2017, 10:48 AM
rhodyguy   Good used (tested) or new on the alt change?   Jun 22 2017, 11:03 AM
Edward Blume   Good used (tested) or new on the alt change? Goo...   Jun 22 2017, 03:41 PM
Edward Blume   Here's the one I pulled. Looks like the boot m...   Jun 22 2017, 04:18 PM
GregAmy   Here's the one I pulled. Looks like the boot ...   Jun 23 2017, 07:49 AM
rhodyguy   Are there arching marks on the inside face of the ...   Jun 23 2017, 07:30 AM
914Tom   only my 2c. If Voltage is correct an it is so. Alt...   Jun 23 2017, 08:00 AM
Edward Blume   Thanks for the great information Spoke! I...   Jul 31 2017, 04:07 PM
porschetub   What did they find wrong with it ?   Jul 31 2017, 04:45 PM
Edward Blume   It tested good but when he opened it up, the diode...   Jul 31 2017, 05:01 PM
Edward Blume   I got the new alternator installed. Fully charged ...   Sep 28 2017, 03:09 PM
Spoke   I got the new alternator installed. Fully charged...   Sep 28 2017, 06:31 PM
Edward Blume   I got the new alternator installed. Fully charge...   Sep 28 2017, 09:16 PM
Edward Blume   I re-read your instructions to test it to ground. ...   Sep 28 2017, 03:38 PM
Perry Kiehl   $200 is a lot. The list for a Bosch reman at...   Sep 28 2017, 04:52 PM
Edward Blume   $200 is a lot. The list for a Bosch reman a...   Sep 28 2017, 09:02 PM
Spoke   Rob, Copying my PM to you with additional info: ...   Sep 28 2017, 06:25 PM
Edward Blume   Rob, Copying my PM to you with additional info: ...   Sep 28 2017, 09:13 PM
- Lo-Fi Version Time is now: 25th November 2026 - 02:03 PM
