FS 1975 914 six conversion with special engine |
housand |
Sep 30 2017, 11:55 AM
I'm new here ... Group: Members Posts: 0 Joined: 18-August 10 From: northern california Member No.: 12,070 Region Association: Northern California |
The one of a kind engine is built as a tribute to the Porsche air cooled engine design with components and improvements considered the best over the 30+ year history of the 911 engine design evolutions.
Engine approximately 5000 miles on rebuild - 1968 early sand cast case (#3380133) bored for 2.7, oil bypass modification, oil squirters added. Work done by Ollies - Original 911S 8.5:1 CIS pistons and Nikasil cylinders. - 74 911S heads with 46/40 valves rebuilt by Ted Robinson at German Precision. - 94 993 cams with keyway, 993 cam towers, 993 valve covers and 993 hydraulic lifters. - Hydraulic chain tensioners. - 911SC aluminum 4 rib oil pump 911-107-008-05 - Original 74 911S CIS fuel injection. - Genuine 914-6 oil tank. Exhaust 993 heat exchangers into dual inlet stock muffler Wheels Genuine Fuchs alloys, rear are deep sixes Brakes and suspension - Front 911S front struts, calipers and rotors with 3.5" caliper mounting - Rear 911S calipers and rotors with drum-in-hat parking brake - 180lb rear springs MSD electronic ignition and distributor module. Body in original condition except for paint. Original paint was L97B Anacona Blue Metallic. No rust. Owned since 1987 asking $37500 cash [attachmentid=622 022] Attached thumbnail(s) Attached File(s) 914_sound_with_993_exhaust.wav ( 763.55k ) Number of downloads: 45 |
rhodyguy |
Sep 30 2017, 01:18 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
That's a lot of car if it checks out. I had no idea 911 HEs could be made to work on a 914. GLWTS.
Lo-Fi Version | Time is now: 2nd June 2024 - 04:55 AM |
