| 914 RZ-1 |
Oct 7 2017, 12:40 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
What is the best/easiest way to make the positive battery cable longer? I do not want to cut it.
I need to temporarily put the battery in the rear trunk. I don't want to cut any cables. I plan to get a longer negative cable assembly but that is not possible with the positive cable. |
| 76-914 |
Oct 7 2017, 01:24 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,964 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Isn't it already long enough to re-route it if you remove the straps that hold it against the rear bulkhead??? (IMG:style_emoticons/default/confused24.gif)
| 914 RZ-1 |
Oct 7 2017, 04:33 PM
Isn't it already long enough to re-route it if you remove the straps that hold it against the rear bulkhead??? (IMG:style_emoticons/default/confused24.gif) No, hence my question. One of the positive cables is long enough, but the other one is not. |
914 RZ-1 How to extend positive battery cable Oct 7 2017, 12:40 PM
porschetub
What is the best/easiest way to make the positive... Oct 7 2017, 01:42 PM
Rand
Buy an extension piece, insulate where you bolt i... Oct 7 2017, 01:45 PM
914 RZ-1
Buy an extension piece, insulate where you bolt ... Oct 7 2017, 04:35 PM
914 RZ-1
[quote name='914 RZ-1' post='2535296' date='... Oct 7 2017, 04:37 PM
porschetub
[quote name='914 RZ-1' post='2535296' date=... Oct 7 2017, 05:57 PM
DM_2000 One way is to get a 2nd cable and place the new ca... Oct 7 2017, 05:47 PM
914 RZ-1 Maybe this will help: I'm going to cut out the... Oct 7 2017, 08:46 PM
Rand
Maybe this will help: I'm going to cut out th... Oct 7 2017, 08:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th September 2026 - 11:15 AM |
