mobymutt |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada ![]() |
Just did a compression check, here's what I measured:
108, 120, 96, 85 I've got a stock 1.8L, but would like to build a 1911 or 2056 in the relatively near future. Hopefully I'll be ok for another year or so with the current setup. |
DM_2000 |
Member ![]() ![]() Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None ![]() |
Do a leak down test, that wil let you know where the losses are. Are the valves adjusted properly? ( RE too tight to the point a valve is staying open will lower compression )
Lo-Fi Version | Time is now: 15th July 2025 - 10:20 AM |
