> 914-4 Battery?
914
post May 3 2016, 08:17 AM
Any Ideas as what is the best battery for a 1971 914-4?
Thanks,914
Cairo94507
post May 23 2016, 08:21 AM
Michael
When it comes time for a battery, it is going to be a sealed battery for sure. No more leaking acid worries, regardless of a battery pad/liner.
dlkawashima
post May 23 2016, 09:53 AM
QUOTE(Cairo94507 @ May 23 2016, 07:21 AM) *
Online battery purchases are 25% off at Pep Boys right now. But be careful about the end date because there appears to be some confusion on their own site about when the sale ends. One link says the end of May while others say the end of June. Might want to call a store to verify.
Here is what gets pulled up when doing a search for Bosch AGM batteries:
https://www.pepboys.com/search/?term=bosch+agm+battery
Example ...
fslick
post Oct 9 2017, 01:58 PM
dlkawashima, do you run a size 34? Would really like a Bosch AGM but worried a size 34 is too/long tall. Looks like Bosch doesn't make an AGM in 96R (or original size 42). Thanks! (IMG:style_emoticons/default/smile.gif)
QUOTE(dlkawashima @ May 23 2016, 11:53 AM) *
Example ...
914   914-4 Battery?   May 3 2016, 08:17 AM
Amphicar770   A lot of people use the Optima batteries. No worr...   May 3 2016, 08:49 AM
malcolm2   A lot of people use the Optima batteries. No wor...   May 3 2016, 09:11 AM
era vulgaris   [quote name='Amphicar770' post='2339580' date='Ma...   May 3 2016, 06:21 PM
1TRICK6   Bosch 96R battery fits perfect. Check PepBoys, usu...   May 3 2016, 09:13 AM
malcolm2   Something else I really like are my connectors. I...   May 3 2016, 09:22 AM
914   Thanks everyone for the reply's.I got the Bosc...   May 3 2016, 06:10 PM
porsche913b_sp   Thanks everyone for the reply's.I got the Bos...   May 3 2016, 08:16 PM
struckn   If it's a Vented Battery, such as I have, buy ...   May 4 2016, 07:42 AM
Drums66   If it's a Vented Battery, such as I have, buy...   Oct 10 2017, 01:41 PM
championgt1   Thanks everyone for the reply's.I got the Bo...   May 5 2016, 09:25 AM
914   Here is the Bosch battery..Again Thanks everyone f...   May 4 2016, 05:35 PM
Amphicar770   Here is the Bosch battery..Again Thanks everyone ...   May 5 2016, 08:24 AM
914   Always used a mat on my Four and Six.. 914   May 5 2016, 08:59 AM
JFG   Any chance you can post the dimendions of the bosc...   May 23 2016, 03:22 AM
dlkawashima   The battery purchased by the original poster is a ...   May 23 2016, 04:32 AM
1stworks   Here's what I did. http://www.914world.com/b...   May 23 2016, 06:59 AM
Cairo94507   When it comes time for a battery, it is going to b...   May 23 2016, 08:21 AM
dlkawashima   When it comes time for a battery, it is going to ...   May 23 2016, 09:53 AM
fslick   dlkawashima, do you run a size 34? Would really li...   Oct 9 2017, 01:58 PM
Philip W.   [quote name='Cairo94507' post='2349034' date='May...   Oct 10 2017, 07:38 AM
fslick   Dr. Phil -- if you do order the Bosch AGM from pep...   Oct 10 2017, 11:52 AM
Philip W.   Dr. Phil -- if you do order the Bosch AGM from pe...   Oct 10 2017, 11:56 AM
arne   I put a Miata U1R AGM in mine. Smaller, lighter, c...   Oct 9 2017, 04:22 PM
fslick   Cool! I think next go around I'll do AGM. ...   Oct 9 2017, 09:03 PM
ThreeV8s   I put a Miata U1R AGM in mine. Smaller, lighter, ...   Nov 3 2017, 05:34 PM
ThreeV8s   I put a Miata U1R AGM in mine. Smaller, lighter,...   Nov 6 2017, 09:16 AM
Coondog   RE: 914-4 Battery?   Oct 9 2017, 10:06 PM
Rand   It's a no-brainer to avoid lead-acid. :sick: T...   Oct 9 2017, 10:48 PM
gereed75   It is pretty common in the experimental aircraft w...   Oct 10 2017, 07:25 AM
arne   It is pretty common in the experimental aircraft ...   Oct 10 2017, 11:55 AM
malcolm2   It is pretty common in the experimental aircraft...   Oct 11 2017, 08:44 AM
mzalanka   [quote name='arne' post='2536236' date='Oct 10 20...   Oct 12 2017, 10:09 PM
porschetub   It is pretty common in the experimental aircraft ...   Oct 10 2017, 03:27 PM
ValcoOscar   Another option: 25% Off Online Orders of Select H...   Oct 11 2017, 08:52 AM
ThreeV8s   Another option: 25% Off Online Orders of Select ...   Oct 12 2017, 07:24 PM
ThreeV8s   Can anyone confirm if this "non-spillable...   Oct 29 2017, 05:02 AM
Elliot Cannon   I just found this tonight. http://www.batterymart...   Nov 6 2017, 10:05 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:32 PM
