Some People Never Learn, repeat offender becomes a "three-peat" offender |
76-914 |
Oct 11 2017, 11:34 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I feel guilty about posting this as others here struggle with their loss from our current fires. Bad timing and I'll blame that on the shipper's. I had planned to have this here 6 weeks ago but due to incompetent shippers (I went thru 3 before I found the right one) it took this long. Bob (Bullit) has the patience of Jobe and was an absolute pleasure to deal with thru out this ordeal.
Body wise, I seem to be regressing as my first 914 is a 76 hence my screen name. The 2nd a 73 and this one's a 70. Engine wise, I'm heading in the right direction. The 1st was a 4 banger, the 2nd a 6 and this one's a V-8. I may or may not keep this one as I can't imagine it handling as well as the other 2 with the higher center of gravity. That and the six is a handful so I can't imagine I'd ever get a handle on the 50% power increase of the 70. But the price was right and I needed something to keep me busy. Speaking of; I can't get the rear trunk open, yet. (IMG:style_emoticons/default/lol-2.gif) This week I plan to familiarize myself with it. Next up; compression and/or leak down test to verify what I've been told about the engine then get it started. Then on to electrical, brakes, transmission, cooling, etc, etc. I'll start a separate build tread shortly! (IMG:style_emoticons/default/beerchug.gif) Stable mates! |
Chris H. |
Oct 12 2017, 08:35 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
What engine is in that thing? What needs to be done to get it running?
76-914 |
Oct 12 2017, 08:25 PM
What engine is in that thing? What needs to be done to get it running? Chris, I'm told it's a 68 327 .30 over (338 ci) flat top's w/ valve reliefs. I haven't ID'd the heads yet but the info I received was 993 heads, 2.02" I & 1.60" E valves, 76cc chambers, estimated cam lift on intake .450". I have nothing on the Ex lift. Compression 9.0. Appx HP 300. What I gleamed from some SBC sites re: torque is maybe 350 ft lbs. I don't yet know if it is a 4 bolt main or not. Moot point for me because IIRC, not much increase in torque after 5000rpm so no need to spool up the RPM's. PO said they did the 20 min break in. It hasn't been fired up since. I won't know Diddley until she fires up. The wiring needs to be sorted out but to answer your question; I need to get 12v to the dizzy/coil, connect fuel lines, fill tank, wire up electric choke and water pump, run and secure radiator lines. Here's a few pic's of the head which I'll need to ID. The last time I worked on an SBC there were only a few heads; Power Pack and FI, IIRC but that was in 1979. From the break in run: Some ID marks on the heads Another Uno mas |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:34 AM |
