> 914-4 Battery?
914
post May 3 2016, 08:17 AM
Any Ideas as what is the best battery for a 1971 914-4?
Thanks,914
gereed75
post Oct 10 2017, 07:25 AM
It is pretty common in the experimental aircraft world to use PC 680's. I use one to crank my 360 cubic inch 9:1 compression Lycoming. Very reliable, AGM, takes abuse and weighs 7 lbs IIRC.
arne
post Oct 10 2017, 11:55 AM
Serial Rescuer of old vehicles...
QUOTE(gereed75 @ Oct 10 2017, 06:25 AM) *
I’ve got an 8 year old PC680 in my 911. Nice battery, but I couldn’t find one locally when I needed one for the 914. Hence the Miata battery.
malcolm2
post Oct 11 2017, 08:44 AM
QUOTE(arne @ Oct 10 2017, 12:55 PM) *
So I assume you have to also buy MALE wire ends or screw in battery posts, cause this one has FEMALE connectors on it. Am I correct?
mzalanka
post Oct 12 2017, 10:09 PM
QUOTE(malcolm2 @ Oct 11 2017, 07:44 AM) *
Yep, but they are standard size, maybe 10 bucks on Amazon. You can probably get them at your FLAPS.
FWIW - I've had the odyssey pc925 in the stock location for about a year, very happy, fits snugly. It's a tad more narrow than the stock battery, so I plan to put in a simple clamp on mine over the winter. I also did the Bosch starter relay kit, which takes all of 10 minutes to install, and that helped tremendously in terms of turning over power.
914   914-4 Battery?   May 3 2016, 08:17 AM
Amphicar770   A lot of people use the Optima batteries. No worr...   May 3 2016, 08:49 AM
malcolm2   A lot of people use the Optima batteries. No wor...   May 3 2016, 09:11 AM
era vulgaris   [quote name='Amphicar770' post='2339580' date='Ma...   May 3 2016, 06:21 PM
1TRICK6   Bosch 96R battery fits perfect. Check PepBoys, usu...   May 3 2016, 09:13 AM
malcolm2   Something else I really like are my connectors. I...   May 3 2016, 09:22 AM
914   Thanks everyone for the reply's.I got the Bosc...   May 3 2016, 06:10 PM
porsche913b_sp   Thanks everyone for the reply's.I got the Bos...   May 3 2016, 08:16 PM
struckn   If it's a Vented Battery, such as I have, buy ...   May 4 2016, 07:42 AM
Drums66   If it's a Vented Battery, such as I have, buy...   Oct 10 2017, 01:41 PM
championgt1   Thanks everyone for the reply's.I got the Bo...   May 5 2016, 09:25 AM
914   Here is the Bosch battery..Again Thanks everyone f...   May 4 2016, 05:35 PM
Amphicar770   Here is the Bosch battery..Again Thanks everyone ...   May 5 2016, 08:24 AM
914   Always used a mat on my Four and Six.. 914   May 5 2016, 08:59 AM
JFG   Any chance you can post the dimendions of the bosc...   May 23 2016, 03:22 AM
dlkawashima   The battery purchased by the original poster is a ...   May 23 2016, 04:32 AM
1stworks   Here's what I did. http://www.914world.com/b...   May 23 2016, 06:59 AM
Cairo94507   When it comes time for a battery, it is going to b...   May 23 2016, 08:21 AM
dlkawashima   When it comes time for a battery, it is going to ...   May 23 2016, 09:53 AM
fslick   dlkawashima, do you run a size 34? Would really li...   Oct 9 2017, 01:58 PM
Philip W.   [quote name='Cairo94507' post='2349034' date='May...   Oct 10 2017, 07:38 AM
fslick   Dr. Phil -- if you do order the Bosch AGM from pep...   Oct 10 2017, 11:52 AM
Philip W.   Dr. Phil -- if you do order the Bosch AGM from pe...   Oct 10 2017, 11:56 AM
arne   I put a Miata U1R AGM in mine. Smaller, lighter, c...   Oct 9 2017, 04:22 PM
fslick   Cool! I think next go around I'll do AGM. ...   Oct 9 2017, 09:03 PM
ThreeV8s   I put a Miata U1R AGM in mine. Smaller, lighter, ...   Nov 3 2017, 05:34 PM
ThreeV8s   I put a Miata U1R AGM in mine. Smaller, lighter,...   Nov 6 2017, 09:16 AM
Coondog   RE: 914-4 Battery?   Oct 9 2017, 10:06 PM
Rand   It's a no-brainer to avoid lead-acid. :sick: T...   Oct 9 2017, 10:48 PM
gereed75   It is pretty common in the experimental aircraft w...   Oct 10 2017, 07:25 AM
arne   It is pretty common in the experimental aircraft ...   Oct 10 2017, 11:55 AM
malcolm2   It is pretty common in the experimental aircraft...   Oct 11 2017, 08:44 AM
mzalanka   [quote name='arne' post='2536236' date='Oct 10 20...   Oct 12 2017, 10:09 PM
porschetub   It is pretty common in the experimental aircraft ...   Oct 10 2017, 03:27 PM
ValcoOscar   Another option: 25% Off Online Orders of Select H...   Oct 11 2017, 08:52 AM
ThreeV8s   Another option: 25% Off Online Orders of Select ...   Oct 12 2017, 07:24 PM
ThreeV8s   Can anyone confirm if this "non-spillable...   Oct 29 2017, 05:02 AM
Elliot Cannon   I just found this tonight. http://www.batterymart...   Nov 6 2017, 10:05 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:32 PM
