> Right head light blowing fuses
JFG
post Oct 12 2017, 01:59 PM
I had a problem whereby the light bucket would not rise but would lower after manually winding it up. I used a check from pelican parts to jump between 87 & 30 in the relay socket (without the relay fitted)
This should jump the motor into a constant raise / lower mode in order to check the motor. It worked the motor perfectly. However when I now refit the relay it blows fuse 12 (16 amp) straight away.
This never happened before and yes I removed the jumper wire first.
Any help with this?
JFG
post Oct 13 2017, 01:01 PM
Thanks for advice. After 3 more blown fuses I figured it was the relay. Strange though as it didn't blow before. Luckily I don't use all relays on the engine board so nabbed one off there and all things work as they should.
jim_hoyland
post Oct 13 2017, 03:50 PM
Get that VIN ?
QUOTE(JFG @ Oct 13 2017, 12:01 PM) *
Was it the relay in the front trunk ? Never had one of those go south.... (IMG:style_emoticons/default/sad.gif)
- Lo-Fi Version Time is now: 8th November 2026 - 12:26 AM
