> Right head light blowing fuses
JFG
post Oct 12 2017, 01:59 PM
I had a problem whereby the light bucket would not rise but would lower after manually winding it up. I used a check from pelican parts to jump between 87 & 30 in the relay socket (without the relay fitted)
This should jump the motor into a constant raise / lower mode in order to check the motor. It worked the motor perfectly. However when I now refit the relay it blows fuse 12 (16 amp) straight away.
This never happened before and yes I removed the jumper wire first.
Any help with this?
jim_hoyland
post Oct 13 2017, 08:02 AM
Get that VIN ?
I just went through a similiar problem; turned out an external diode on the outer side of the HL Motor had broken and was shorting. Not easy to see at first; you have to poke around. Plus the diode is loosely covered by a black covering.
Some peeps have soldered the diode back; I replaced the Motor with one I got from Bruce Stone.
See Andy thread with pictures of the problem:
http://www.914world.com/bbs2/index.php?sho...=263805&hl=
post Oct 13 2017, 04:26 PM
QUOTE(jim_hoyland @ Oct 13 2017, 07:02 AM) *
That's a damned good tip, Jim. Now if only I can remember that when and if the time comes. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 8th November 2026 - 12:26 AM
