Type-IV Crank mods, What needs to be done? |
URY914 |
Nov 4 2004, 12:11 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,968 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
What needs or can be done to a 2.0 crank to improve on it?
Knife edge? Polish it? High tech coatings? Soak it in Jack? (and don't give me any shit like "drill it full of holes to lighten it' (IMG:style_emoticons/default/wacko.gif) ) Paul |
914forme |
Nov 4 2004, 03:22 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Dry sump it and be done! The rest becomes much less important, anyway, your crank should not be down in oil, if it is, you got bigger problems than what a knife edge will fix. The cam is down there more than the crank. I would hate to think I have 8 lifters pumping oil up the push rod tubes! That would be a big HP robber. Note I said tubes and not pushrods, oil travels up the pushrods and drains down the tubes.
If you are worried aboout it get a good balance job, everything needs to be balanced from fan bolts to pressure plate bolts, and you need all of it indexed for assembly. With out indexing how do you know which piece went where when balanced. Get it as close as you can, you can spin it up to 8K, and not worry about it. It won't feel like a single cyclinder cafe bike, which I love to ride, but thumper comes to mind. When you pick a balancer make sure you look at the jobs comming out of the shop, as for a referance and see the work. If you see them drilling stuff, then walk away, if they don't give you piece of paper with all the indexing and weights walk away. I would pay the 2-3 hundred on balancing before I would do anything else. After that the proper cam, and then head work, then down hte list from there. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:51 AM |
