Front Oil cooler size for bigger six |
Justinp71 |
Oct 11 2017, 10:00 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
So I rebuilt my 3.0 into a much higher hp 3.2, I think its pushing 280hp. Problem now is just spirited street driving it runs at 210f with it be 80f outside; I'm sure on the track it will run 230+. I am running an engine cooler and the factory GT style Setrab oil cooler. If I want to run more track how large of an oil cooler do I need? What have you guys done in the past?
Also I am only running a GT lower valance, not a GT bumper, the hole seems large enough, could the GT bumper make that big a difference? Attached thumbnail(s) |
ablesnead |
Oct 14 2017, 03:40 PM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
I'm going to open a can of worms on this response to Andys photos of his hood vent . I am tired of dodging the intermittent rain here while trying to work on my sail boat , So what the heck , I may learn something . Several months ago , there was a thread that was discussing how to exit the warm air from your front mount cooler....Tons of ideas where mentioned but the first absolutely thing you would never do is duct it under the car....I think that may be completely false...an assumption like the need to adjust back pressure in tuning , or some such baloney....914 's generate lift...watch the rear in in a high speed turn....warm air creates lift in two ways , less density and higher velocity . Both would normally be desirable under a car ( lower pressure ) both would be undesirable over the car...again Lower pressure....ground effect devices that harness the air for a designed purpose are exempt from the above , if they exist
SirAndy |
Oct 14 2017, 07:00 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm going to open a can of worms on this response to Andys photos of his hood vent . I am tired of dodging the intermittent rain here while trying to work on my sail boat , So what the heck , I may learn something . Several months ago , there was a thread that was discussing how to exit the warm air from your front mount cooler....Tons of ideas where mentioned but the first absolutely thing you would never do is duct it under the car....I think that may be completely false...an assumption like the need to adjust back pressure in tuning , or some such baloney....914 's generate lift...watch the rear in in a high speed turn....warm air creates lift in two ways , less density and higher velocity . Both would normally be desirable under a car ( lower pressure ) both would be undesirable over the car...again Lower pressure....ground effect devices that harness the air for a designed purpose are exempt from the above , if they exist I'll give you some real world experience to your theoretical engineering since i used to vent the hot air under the car for several years before i went with the shroud and hood vent. I can tell you in no uncertain terms that the car handles *much* better now at high speeds of 100+ mph. There's no if, but or maybe about it. Before, my car was scary at those speeds with the rear end being completely lose and all over the place. Now the car is firmly settled and the rear end is a lot more stable all the way up to my speed limit of about 135mph. I'm sure there'll be plenty of theoretical this and that about how that is caused by some or such not related to the venting, but all i changed was the routing of the hot air. Nothing else has changed on the car. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 5th June 2024 - 01:35 AM |
