> Inverted 915 Project, No Description needed
pcar916
post Sep 18 2017, 06:06 PM
Is that a Lola?
Hi Folks,
I'm returned after a brief hiatus with a question. Some of you remember I have Penelope, a 914/993 machine. I have decided to replace the 914 transaxle with an inverted 915. How many of you have done it and do you have stories? :-) My thinking is as follows...
1. Billet side plate. I've already paid the price several times for deflection. The 993 is not a huge hp machine, maybe 270hp with a bit less torque depending on the RPM/throttle.
2. Cable shifter (any suggestions that don't include making one myself.) It would be fun but might take longer than I want to wait.
3. Already have the turbo flanges/CV's to accommodate the deflection angle.
4. Oil cooler already installed whether I need it or not. Already addressed in the trans cooler thread from years ago.
Thought seriously about building a side shifter 915 with Bott's kit, but as good as it is, and it is. I don't want to take the gear-stack out every time I want to check the LSD plates/R&P.
I've gotten a replacement 993 engine while I jazz up her (tired) original engine, but since I haven't done one of these builds, I figured I'd ask this crowd about it because I'd rather drive her while I build the engine.
Glad to be back!
Ron
pcar916
post Oct 23 2017, 10:49 AM
Is that a Lola?
Thanks Gents,
ConeDogger: "McMark has the design for a cable shifted 915 in his head and computer"
I'll follow up and see if his shifter is aftermarket or not. Also, I wish I could move the Guard LSD from the 914 to the 915 box... the bearing surfaces aren't the same size though.
Jeff: Wevo's a nice solution. But it's for a non-inverted 915. Inversion puts the shift rod on the top where a standard rod system doesn't reach without universal joints, cams and levers. Non-inverted leaves me with a flipped R&P and more complicated diff maintenance.
Cracker: That shifting is wonderful!
Since I can't start working on my 914 until I get finished with current projects I have time to noodle over this a bit. If I can figure out how to do the G86/20 box I'll sell off the 915's and a few of the 914 boxes... clear out some space!
Lookin' forward to ceasing the engineering work and building it instead!
Thanks again guys.
Ron
pcar916   Inverted 915 Project   Sep 18 2017, 06:06 PM
Cracker   No matter what you do with a 915...it is still a 9...   Sep 18 2017, 06:29 PM
mepstein   Why don’t you flip the differential. It’s been...   Sep 18 2017, 07:49 PM
Cracker   ...and in the end, it still shifts like a crappy o...   Sep 18 2017, 07:54 PM
mepstein   I agree, a 915 box shifts like a 915 box but I lea...   Sep 18 2017, 08:13 PM
pcar916   I agree, a 915 box shifts like a 915 box ... Ton...   Oct 9 2017, 11:06 AM
mepstein   I agree, a 915 box shifts like a 915 box ... To...   Oct 9 2017, 11:58 AM
Cracker   Ron, I never posted a "build thread" fo...   Oct 9 2017, 06:21 PM
pcar916   Ron, I never posted a "build thread" f...   Oct 12 2017, 01:19 PM
stownsen914   I know I'll have to do the following to the ...   Nov 1 2017, 12:03 PM
pcar916   1. When you say you need a different clutch/flywh...   Nov 3 2017, 07:05 AM
Justinp71   How does the 915 shift compared to a 901? I have a...   Sep 19 2017, 11:49 AM
pcar916   Sorry folks... busier than a one-armed paper hange...   Sep 20 2017, 05:22 PM
Cracker   If you would seriously consider the Boxster/Cayman...   Sep 21 2017, 04:41 AM
campbellcj   I've always circled around this topic myself a...   Sep 22 2017, 07:45 AM
brant   I've always circled around this topic myself ...   Sep 22 2017, 09:03 AM
campbellcj   I've always circled around this topic myself...   Sep 22 2017, 07:05 PM
ConeDodger   McMark has the design for a cable shifted 915 in h...   Oct 12 2017, 02:04 PM
jeff   What about this option, https://www.wevo.com/Pro...   Oct 12 2017, 02:05 PM
Cracker   Ron, Converting the shift method that was origina...   Oct 12 2017, 03:52 PM
pcar916   Thanks Gents, ConeDogger: "McMark has the des...   Oct 23 2017, 10:49 AM
GeorgeRud   My Vellios 915 shifts fine after some fiddling, bu...   Jan 28 2018, 10:34 PM
Matt Romanowski   I have the Bott kit on a 915. It's night and d...   Feb 1 2018, 03:46 PM
pcar916   The Bott kit is pretty indeed.   Feb 6 2018, 10:05 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:38 PM
