No electrons in, the battery. |
Elliot Cannon |
Oct 24 2017, 01:55 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
It is forecast to be 102 here today, so I thought I would take one of the many twisties from hear down to Morro Bay for fish and chips. Got in the car, turned the key and NOTHING.
Note to self: Whenever my 2 year old Grand Daughter (IMG:style_emoticons/default/wub.gif) is playing in Grandpas' 914, make sure all the switches are back to normal when the little darling gets out. (IMG:style_emoticons/default/headbang.gif) Attached image(s) |
euro911 |
Oct 25 2017, 08:44 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Most of the 'smart' chargers ain't too smart at times, so I've piggy-backed another 'good' battery to trick them too. I also have a brute charger for when the smart-ass chargers refuse and I don't care to lift a battery out of one of the other vehicles. I keep a Deltran 'Battery Tender'® connected to the Harley the entire time it's parked in the garage.
Word of caution - some auto manufacturers recommend disconnecting one of the battery cables before charging your battery. Yes, you might loose your radio presets, and if you have an impending smog test, you may loose ECU history data, which may cause a normally good clean running vehicle from passing said smog test. Some vehicles need to be driven up to 300 miles for the ECU to clear error codes, or provide adequate data to the smog test computer. It happened with my Tacoma last year, but luckily, only took about 60 miles to clear the code(s) ... and passed the smog re-test just fine (for an additional $ amount) (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:36 PM |
