| tornik550 |
Oct 27 2017, 04:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am trying to use a aftermarket VDO fuel gauge. I am not very clear of how to wire it. Obviously positive goes to switched positive, neg to ground however I wasn’t sure where to connect the sender post on the back of the gauge? I tried hooking it up to the “G” post of the gas tank sender- gauge then reads 0 (even though tank is full). I tried hooking it up to the “WK” post on the gas tank sender and the level goes up to 3/4- even though tank is full. I have used an old gas sender and a brand new one and the same thing happens with both.
theer Are you sure the VDO gauge is calibrated to the se... Oct 27 2017, 05:14 PM
tornik550
Are you sure the VDO gauge is calibrated to the s... Oct 27 2017, 05:21 PM
theer If you take out the sending unit you can imitate a... Oct 27 2017, 05:28 PM
GregAmy Most OE fuel senders change impedance. Most afterm... Oct 27 2017, 06:12 PM
Dave_Darling The 914 gauge reads resistance. I believe it read... Oct 27 2017, 08:34 PM
GeorgeRud There are two contacts on the sender, one for the ... Oct 27 2017, 08:57 PM
GeorgeRud The green wire should be the gauge and the black w... Oct 27 2017, 09:20 PM
larryM there is a VDO VW-Bug gauge that is a near-perfect... Oct 28 2017, 08:54 PM
larryM here is the info from 2004 for correct gauge
... Oct 29 2017, 12:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:40 PM |
