> Aftermarket VDO fuel gauge help needed
tornik550
post Oct 27 2017, 04:55 PM
I am trying to use a aftermarket VDO fuel gauge. I am not very clear of how to wire it. Obviously positive goes to switched positive, neg to ground however I wasn’t sure where to connect the sender post on the back of the gauge? I tried hooking it up to the “G” post of the gas tank sender- gauge then reads 0 (even though tank is full). I tried hooking it up to the “WK” post on the gas tank sender and the level goes up to 3/4- even though tank is full. I have used an old gas sender and a brand new one and the same thing happens with both.
theer
post Oct 27 2017, 05:14 PM
Are you sure the VDO gauge is calibrated to the sending unit?
I believe the 914 sender is 0 ohms for full and 70 ohms at empty - or the other way around?
Anyway, some manufacturers have them the other way around and different ranges (e.g. 180 ohms = full, zero = empty).
- Lo-Fi Version Time is now: 2nd April 2026 - 01:41 PM
