> Aftermarket VDO fuel gauge help needed
tornik550
post Oct 27 2017, 04:55 PM
I am trying to use a aftermarket VDO fuel gauge. I am not very clear of how to wire it. Obviously positive goes to switched positive, neg to ground however I wasn’t sure where to connect the sender post on the back of the gauge? I tried hooking it up to the “G” post of the gas tank sender- gauge then reads 0 (even though tank is full). I tried hooking it up to the “WK” post on the gas tank sender and the level goes up to 3/4- even though tank is full. I have used an old gas sender and a brand new one and the same thing happens with both.
theer
post Oct 27 2017, 05:28 PM
If you take out the sending unit you can imitate an empty tank then check the reaction on your gauge(s). With an ohm meter you can also check the empty/full range to verify the sender is working.
I'm having similar problems with aftermarket fuel gauge in my 944 track car. With that I'm using a VW Beetle gauge where the ohms works in the same direction and added a 10 ohm resistor in line to better line up the ohm range at empty. Not perfect, but close enough for a track car.
Good luck
- Lo-Fi Version Time is now: 2nd April 2026 - 01:41 PM
