| tornik550 |
Oct 27 2017, 04:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am trying to use a aftermarket VDO fuel gauge. I am not very clear of how to wire it. Obviously positive goes to switched positive, neg to ground however I wasn’t sure where to connect the sender post on the back of the gauge? I tried hooking it up to the “G” post of the gas tank sender- gauge then reads 0 (even though tank is full). I tried hooking it up to the “WK” post on the gas tank sender and the level goes up to 3/4- even though tank is full. I have used an old gas sender and a brand new one and the same thing happens with both.
| Dave_Darling |
Oct 27 2017, 08:34 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The 914 gauge reads resistance. I believe it reads low resistance when the tank is full, and high resistance when it is empty. Check the signal from the sender to make sure.
The "G" should be the signal for the gauge, the "WK" is the ground/disconnected that turns on the warning light. The three parallel lines are the ground connection. You do need that hooked up to ground, of course. --DD |
tornik550 Aftermarket VDO fuel gauge help needed Oct 27 2017, 04:55 PM
theer Are you sure the VDO gauge is calibrated to the se... Oct 27 2017, 05:14 PM
tornik550
Are you sure the VDO gauge is calibrated to the s... Oct 27 2017, 05:21 PM
theer If you take out the sending unit you can imitate a... Oct 27 2017, 05:28 PM
GregAmy Most OE fuel senders change impedance. Most afterm... Oct 27 2017, 06:12 PM
GeorgeRud There are two contacts on the sender, one for the ... Oct 27 2017, 08:57 PM
GeorgeRud The green wire should be the gauge and the black w... Oct 27 2017, 09:20 PM
larryM there is a VDO VW-Bug gauge that is a near-perfect... Oct 28 2017, 08:54 PM
larryM here is the info from 2004 for correct gauge
... Oct 29 2017, 12:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:39 PM |
