Which bushes/bearings rear arms? |
JFG |
Oct 29 2017, 11:21 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I stripped the passenger side suspension today and found the following
Disc worn in an offset way Wheel bearing noisy when spun Play in the trailing arm bush nearest engine. I've never driven this car but I can tell the above is not good! Can someone help me with which part numbers I should be ordering and which part fits next to engine and which fits on fender side? It's a stock road car so no desire for poly bushes. |
Mikey914 |
Oct 29 2017, 11:53 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I believe you are describing the bushings in the assembly #1
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 06:09 AM |
