> Aftermarket VDO fuel gauge help needed
tornik550
post Oct 27 2017, 04:55 PM
I am trying to use a aftermarket VDO fuel gauge. I am not very clear of how to wire it. Obviously positive goes to switched positive, neg to ground however I wasn’t sure where to connect the sender post on the back of the gauge? I tried hooking it up to the “G” post of the gas tank sender- gauge then reads 0 (even though tank is full). I tried hooking it up to the “WK” post on the gas tank sender and the level goes up to 3/4- even though tank is full. I have used an old gas sender and a brand new one and the same thing happens with both.
larryM
post Oct 28 2017, 08:54 PM
emoze
there is a VDO VW-Bug gauge that is a near-perfect match to the 914 sender
i've used it in my -6 for about 15+ yrs
- i posted that info L-O-N-G ago - see message below (IMG:style_emoticons/default/cheer.gif)
larryM
post Oct 29 2017, 12:41 PM
emoze
here is the info from 2004 for correct gauge
"here is the answer via VDO Support:
Use VDO Part Number 301 020 with the OEM 914 fuel sender; (spec'd for Beetle O.E. sender or VDO 221012 sender): 73 - 10 Ohms, "Fuel"
The reading will be off slightly but will not be noticeable
William M. Reichart
Technical Support
Siemens VDO Automotive Corporation
Service & Special Solutions
Phone: 1-800-265-1818 Ext. 4018
QUOTE(larryM @ Oct 28 2017, 07:54 PM) *
- i posted that info L-O-N-G ago (IMG:style_emoticons/default/cheer.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 01:40 PM
