wiper motor testing |
JFG |
Oct 20 2017, 01:23 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Olympic 914 |
Oct 20 2017, 05:50 PM
Group: Members Posts: 1,675 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I went through this myself, but mine did run. This may help.
http://www.914world.com/bbs2/index.php?sho...=304921&hl= I rigged up a switch to mimic the column switch to put it in the PARK position. |
Red76 |
Oct 29 2017, 05:12 PM
Newbie Group: Members Posts: 37 Joined: 28-December 16 From: East Tennessee Member No.: 20,703 Region Association: None |
I went through this myself, but mine did run. This may help. http://www.914world.com/bbs2/index.php?sho...=304921&hl= I rigged up a switch to mimic the column switch to put it in the PARK position. Hey man, I must have the same motor as you. Mine does exactly the same thing yours did when i bench test it. Can you pass along how you rigged up a switch to trick the motor into parking on the bench test? It would be greatly appreciated. |
Olympic 914 |
Nov 1 2017, 05:21 PM
I went through this myself, but mine did run. This may help. http://www.914world.com/bbs2/index.php?sho...=304921&hl= I rigged up a switch to mimic the column switch to put it in the PARK position. Hey man, I must have the same motor as you. Mine does exactly the same thing yours did when i bench test it. Can you pass along how you rigged up a switch to trick the motor into parking on the bench test? It would be greatly appreciated. Looks like you figured out a way to determine the park position. I found a picture of the switch I used. Now lets see if I can get this right again. ------------------------------------------ First connect a ground from battery to the wiper body. the green wire on switch to 31b The red center wire on switch to 53 The yellow wire on switch to 53a positive power wire also connects to 53a ------------------------------------------------ Now when switch is in position to activate the yellow wire wiper motor runs in low speed. (skip center position on switch) When green wire is activated the motor will run until it reaches the park position and then will stop. If you want to test the high speed you would connect the center red wire to 53b instead of 53. and when you flick the switch the other way it will park. This diagram MAY help explain it. In this diagram 53e = 31b on our switch. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:59 PM |
