Replaced Shifter Bushings - What Did I do Wrong?, Transmission Shifter Linkage Bushing, spring |
Movin6 |
Sep 25 2016, 12:59 PM
Member Group: Members Posts: 76 Joined: 27-July 09 From: New England Member No.: 10,615 Region Association: North East States |
After I put the shaft back on, fourth and fifth gear require pressing against the spring. The 'neutral position' (no spring force) is the middle gears - Second and third.
Confused since the coupler has a set screw for positioning as dies the back end with the ball cup. I did not touch anything inside the car. (Just coupler bushings, rear bushing that the rod goes through at the side shifter, and the ball cup.) Can I buy a clue?! Thanks in advance. |
Keith914 |
Sep 25 2016, 02:41 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
I have discovered that very small rotation adjustments with the linkage make a big difference and new bushings can cause this. Try this which worked for me from a fellow 914W Jim Hoyland. Start by loosening the pinch bolt on the shifter bushing under the shift handle. With vice grips secure the shift rods under the engine rotated (clockwise lookin forward) fimly in the 4th gear position. Return to th cabin and secure the shift lever over towards the passenger side with a bunjy cord. Place the shift lever in your preferred forward/back position for 4th gear. Tighten the pinch bolt. Hopefully "walla".
Movin6 |
Oct 3 2016, 07:57 PM
This procedure pretty much worked. I say pretty much, because I'm very close, but not quite there... Seems very small rotation of the rod in the pinch bolt at the shifter make a large difference.
Right now, the first to second shift puts me in 4th gear. So I am still pressing against the '1st & Reverse spring', if that makes sense. Which way do I want to move the shifter when I loosen it? Sightly to the right, correct? i.e. towards 4th and 5th. I have discovered that very small rotation adjustments with the linkage make a big difference and new bushings can cause this. Try this which worked for me from a fellow 914W Jim Hoyland. Start by loosening the pinch bolt on the shifter bushing under the shift handle. With vice grips secure the shift rods under the engine rotated (clockwise lookin forward) fimly in the 4th gear position. Return to th cabin and secure the shift lever over towards the passenger side with a bunjy cord. Place the shift lever in your preferred forward/back position for 4th gear. Tighten the pinch bolt. Hopefully "walla". |
Movin6 |
Nov 2 2017, 03:37 PM
Following up in case it helps someone else. I now have all gears, second is right at the 'edge' of the spring. What worked for me was grabbing the shift shaft in the tunnel with a pair of hose-gripper-pliers. The kind with the curved jaws, to encircle the whole shaft. I would hold with the pliers and move the shaft ever so slightly while loosening the clamp at the shifter. Many tries and test drives were needed. and patience!
Thanks for all the replies and help! This procedure pretty much worked. I say pretty much, because I'm very close, but not quite there... Seems very small rotation of the rod in the pinch bolt at the shifter make a large difference. Right now, the first to second shift puts me in 4th gear. So I am still pressing against the '1st & Reverse spring', if that makes sense. Which way do I want to move the shifter when I loosen it? Sightly to the right, correct? i.e. towards 4th and 5th. I have discovered that very small rotation adjustments with the linkage make a big difference and new bushings can cause this. Try this which worked for me from a fellow 914W Jim Hoyland. Start by loosening the pinch bolt on the shifter bushing under the shift handle. With vice grips secure the shift rods under the engine rotated (clockwise lookin forward) fimly in the 4th gear position. Return to th cabin and secure the shift lever over towards the passenger side with a bunjy cord. Place the shift lever in your preferred forward/back position for 4th gear. Tighten the pinch bolt. Hopefully "walla". |
porschetub |
Nov 2 2017, 04:30 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Following up in case it helps someone else. I now have all gears, second is right at the 'edge' of the spring. What worked for me was grabbing the shift shaft in the tunnel with a pair of hose-gripper-pliers. The kind with the curved jaws, to encircle the whole shaft. I would hold with the pliers and move the shaft ever so slightly while loosening the clamp at the shifter. Many tries and test drives were needed. and patience! Thanks for all the replies and help! This procedure pretty much worked. I say pretty much, because I'm very close, but not quite there... Seems very small rotation of the rod in the pinch bolt at the shifter make a large difference. Right now, the first to second shift puts me in 4th gear. So I am still pressing against the '1st & Reverse spring', if that makes sense. Which way do I want to move the shifter when I loosen it? Sightly to the right, correct? i.e. towards 4th and 5th. I have discovered that very small rotation adjustments with the linkage make a big difference and new bushings can cause this. Try this which worked for me from a fellow 914W Jim Hoyland. Start by loosening the pinch bolt on the shifter bushing under the shift handle. With vice grips secure the shift rods under the engine rotated (clockwise lookin forward) fimly in the 4th gear position. Return to th cabin and secure the shift lever over towards the passenger side with a bunjy cord. Place the shift lever in your preferred forward/back position for 4th gear. Tighten the pinch bolt. Hopefully "walla". Keith is total correct,this is exactly how I have recently done mine,I did it twice moving the rod to the right ,first time I found the gate wrong but not by much,one more adjustment and the shaft gate was spot on,hard to explain but you know when its right because the shift lever goes where you point it was little resistance. I have found clutch adjustment fiddly but since I packed out the throwout bearing arm pivot I have touched the adjustment since. Good luck. |
Lo-Fi Version | Time is now: 9th June 2024 - 12:19 AM |
