DougC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 ![]() |
I'm doing custom bolsters on stock 914 seats and need some help. I'm using wire bolster frames from stock BMW seats from my M3 (they were really raggidy). I've mounted the frames using screw head machine bolts and nuts attached to the stock fiberglass. I will be slathering on the Bondo at all the attachment points tonight and letting it set up for a couple of days. Then I plan on doing final adjustments with a propane torch before adding the cushion bolster pads, to get the angles right. I will be using the stock BMW cushions which are(seem) huge. I've started to "shave" them down using an electric knife (probably a cheap one) and it's chewing the cushions up a bit, like it's not sharp enough. I've also used a razor blade without great results. This elec. knife is brand new [got mother-in-law's permission] BTW. I fill confident in my ability to get the contours just right as long as I could find something to cut with. Any suggestions? Here's a preliminary pic of the framed seats.
Doug C Attached image(s) ![]() |
dflesburg |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None ![]() |
I wouldn't do bondo, there is no strength there.
I would use fiberglass and lots of cloth in it... Then, to cut the foam, you can use a fine hack saw blade if you can't borrow a foam saw. I wrap tape around one end so I don't cut my hand. Go slow and be carefull. From the looks of your pics, you will snap those bolsters off ( or your date will - lol ) You need reenforcement, not cosmetics... There is my two cents on seat fabrication. See my post above for my pics. |
Lo-Fi Version | Time is now: 1st July 2025 - 06:01 AM |
