> OT: Airliner air conditioning, I know someone here will know this...
URY914
post Nov 5 2004, 02:17 PM
On a car the a/c compressor runs off the engine.
In a house the a/c compressor is run by an electric motor.
(you can figure out my next question, can't you?)
How is the compressor on a airliner (737, 747,etc) powered?
I've never noticed a big v-belt on the engine before.
If it is powered by a electric motor, if so how is the generator powered? Is there some type of power take off from jet engines?
Thanks,
Paul
spare time toys
post Nov 5 2004, 03:50 PM
hooked on grilling food.
It takes air off the compressor section. Depending on what stage it is coming off of it could be upwards of 490 Deg. F( if over that you should get a pack trip) It then goes into a precooler at the pylon. From there it goes into two big heat exchangers and an air cycle mechiene ( think a big turbo) and past the 35 degree valve then into a water seperator. The 35 deg. valve injects hot air back in so the water seps dont freeze.After that it goes into the distribution bay at the back of the forward bag bin then off to cool little Timmy on his way to Grandmas. The out flow valve at the rear closes to start presureization. but as you climb the pres actually decreases from ground pres. The cabin altitude will climb to aprox 10000 feet while the airframe is at 30000+ when you come down it increases the cabin pres to field elevation. That is basicaly it. Hope this helps.
URY914   OT: Airliner air conditioning   Nov 5 2004, 02:17 PM
Cano   It is my understanding, from watching something on...   Nov 5 2004, 02:21 PM
itsa914   I thought the pilot just opened a window :blink: ...   Nov 5 2004, 02:26 PM
Headrage   Engine bypass air.   Nov 5 2004, 02:27 PM
URY914   <...   Nov 5 2004, 02:29 PM
Headrage   On all the planes I worked on, they had ducting th...   Nov 5 2004, 02:35 PM
SLITS   Also, consider the temp of the intake air at altit...   Nov 5 2004, 02:37 PM
URY914   So the turbine would only be spinning with enough ...   Nov 5 2004, 02:38 PM
2-OH!   On the ground, air is bled off the APU (auxillary ...   Nov 5 2004, 02:45 PM
Kerrys914   Well in flight. How about no compressor at all :o ...   Nov 5 2004, 02:45 PM
maf914   ...   Nov 5 2004, 03:39 PM
redshift   lol m   Nov 5 2004, 03:48 PM
spare time toys   It takes air off the compressor section. Dependin...   Nov 5 2004, 03:50 PM
SLITS   And if you board a plane in Norfolk, VA in the sum...   Nov 5 2004, 04:00 PM
J P Stein   The new CF 7E7 is gonna eliminate bleed air ducti...   Nov 5 2004, 04:00 PM
spare time toys   ...   Nov 5 2004, 04:11 PM
Elliot Cannon   Bleed air ain't free. Cheers, Elliot   Nov 5 2004, 05:37 PM
Dominic     Nov 5 2004, 11:48 PM
URY914
- Lo-Fi Version Time is now: 3rd July 2025 - 10:58 PM
