Hit and Run Victiom, becoming a GT conversion... |
CG-914 |
Nov 11 2017, 10:44 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Last night on my commute home my '74 914 2.0 was hit in the rear by a Mercedes Sedan, the driver fled the scene (IMG:style_emoticons/default/headbang.gif) and my insurance company explained to me today, that yes, you are insured against uninsured drivers and therefore against hit and run accidents but only for medical expenses (IMG:style_emoticons/default/barf.gif) , I guess next time I read the fine print better.
Now i need to fix the body and get a new paint job so I guess its time for the GT flares, 5 Lug conversion, Brake upgrade and Fuchs. I do have some questions that I hope to get answered: - Which are the best (probably steel) GT flares, also for the money? - Where do I get the best fibreglass bumpers? GTracing? - Do 8 inch fuchs fit in the rear? - Whats the best spindle and hub to use in the front, I do want to run at least SC Calipers and the matching vented discs? - What parts exactly of the 76/77 911 rear hub do I need for the rear conversion to five lug? I know these are a lot of questions I hope you guys can help. Thank you Cornelius PS Maybe somebody has seen something on the 91 west bound in LA on Friday around 6:50 pm?! |
GeorgeRud |
Nov 12 2017, 10:16 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
The AA flares are fine to use and really duplicated the factory pieces. They will easily fit 8” wheels, and it’s a good idea to have them mounted on the car when fitting the flares. Ben’s pieces are works of art and should help you do a conversion. Several different options are available for the front engine mount. You could also replace the front struts with Carrera struts to take advantage of the larger brake discs, but SC ones would also be great. PMB can provide any brake components you might need.
Though it doesn’t look bent, you might want to mount the chassis on a Celette Bench to check it before doing any other repair work. Enjoy the project! |
Lo-Fi Version | Time is now: 28th May 2024 - 11:35 PM |
