hand throttle vs cold start circuit, Anyone use the CSC on Webers? |
bbrock |
Nov 13 2017, 03:50 PM
My Webers have the cold start circuits installed. While I'm replacing the floor pan and have easy access to the tunnel, I am thinking about adding a couple tubes to run cables from a hand throttle lever to the carbs to operate the chokes. Wondering if anyone has done this and whether it would provide superior cold starting to the traditional hand throttle. I live in the frigid north where it can freeze any day of the year, so I want the best cold start operation I can get. Thoughts?
nditiz1 |
Nov 13 2017, 06:09 PM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Mine did have the CSC hooked up on both carbs. I will most likely not use it as I am trying to clean up the engine bay.
The PO was into bicycles and used a hand lever hooked to a central mount point. There was a bracket mounted at the rear of the engine on the top. The cable inside would pull both levers open all via bicycle brake/gear cables. It was a pretty neat setup. PM if interested in having my old setup. The lever was mounted just behind the E-brake, but could be mounted anywhere really. |
Lo-Fi Version | Time is now: 16th June 2024 - 06:56 PM |
