Poker Run, planning info |
seanery |
Nov 1 2004, 03:56 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Scott,
Our Poker Run went pretty well. Everyone seemed to enjoy it and no one was arrested! ask "Site (Mike Clark)" about that one. Our format was somewhat determined by the Columbus Architectural Tour. I used their map that has 70+ locations marked and then wrote clues to point you to the right location. We had 10 stops including the hotel and the Visitor's Center - where everyone received a map and their 1st card. We staggered the start by 2 minutes per car. Not every stop had a person there, 6 did, including the last stop which was the park where lunch was. I made 3 different versions of directions (so people wouldn't just follow each other), but actually told them that each map was different, I know I'm sly. (IMG:style_emoticons/default/wacko.gif) I think only 2 people found all the locations correctly, but all ended up at the Lunch location in a reasonable time frame. We had some good hands, 1 group had 2 pair and 2 groups had 3 of a kind, 3s and the other had jacks. I purchased 8 different decks of cards, the differences were somewhat subtle to totally different. I would lean toward totally different decks next time. This eliminates the possibility of someone showing up with a couple decks of Bicylcle cards and making their own hand. Things that will help you make the WCC Poker Run a success, I'm sure there are more than just this:
VegasRacer |
Nov 5 2004, 09:21 PM
ELVIRA Group: Benefactors Posts: 8,524 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
I forgot to tell you that the estimated production time for the gold foil hot stamped chips is 2 weeks and it will take 4 weeks for the full color photo quality ones.
BTW - how many decks of cards will we need? Do you want 'em all different or do you want 2 each? Two each would mean you would have 104 matching cards at each check point. I guess the real question is how many check points will you have on the Poker Run? Gotta have at least 5. Seven might be a good number to aim for. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:22 AM |
