Tire rubbing, Need to stretch the rear fender a little. But how? |
HansJan |
Nov 11 2017, 07:58 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Today I had new rear tires installed. A family member has this size tire on his 914-6, and it looks great. So I got the same. 225-50-16 on 7” rims.
They clear the fenders (which had been rolled by PO). Passenger side has plenty of clearance at 1/4”. Driver side not so much, just enough to slide a thin cardboard between tire and fender while bouncing on back of the car. All is fine in a straight line. But Passenger side starts rubbing at right-hand turn. See pictures below to spot the rubbing location (paint starts to blister a little). Should I try to stretch the fender a little? Or... Is it possible to create some room by adding a shim to change the camber? Thanks for letting me use the collective brainpower. Attached thumbnail(s) |
Rand |
Nov 14 2017, 10:34 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Wood form, porta power, push it 1/8 of an inch. Seriously changing tires because one side is off by that much? Fair enough I guess, but I'd just nudge it and run the tires I want. Nobody would see it. Just equalizing.
Lo-Fi Version | Time is now: 1st June 2024 - 12:26 AM |
