Some People Never Learn, repeat offender becomes a "three-peat" offender |
76-914 |
Oct 11 2017, 11:34 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I feel guilty about posting this as others here struggle with their loss from our current fires. Bad timing and I'll blame that on the shipper's. I had planned to have this here 6 weeks ago but due to incompetent shippers (I went thru 3 before I found the right one) it took this long. Bob (Bullit) has the patience of Jobe and was an absolute pleasure to deal with thru out this ordeal.
Body wise, I seem to be regressing as my first 914 is a 76 hence my screen name. The 2nd a 73 and this one's a 70. Engine wise, I'm heading in the right direction. The 1st was a 4 banger, the 2nd a 6 and this one's a V-8. I may or may not keep this one as I can't imagine it handling as well as the other 2 with the higher center of gravity. That and the six is a handful so I can't imagine I'd ever get a handle on the 50% power increase of the 70. But the price was right and I needed something to keep me busy. Speaking of; I can't get the rear trunk open, yet. (IMG:style_emoticons/default/lol-2.gif) This week I plan to familiarize myself with it. Next up; compression and/or leak down test to verify what I've been told about the engine then get it started. Then on to electrical, brakes, transmission, cooling, etc, etc. I'll start a separate build tread shortly! (IMG:style_emoticons/default/beerchug.gif) Stable mates! |
Dr Evil |
Nov 14 2017, 02:31 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
76-914 |
Nov 15 2017, 10:50 AM
It should be OK. It came from one of your east coast rebuild clinic's and has the "H" gear. I don't plan on stomping on it off the line. Hopefully one of the fuses, aka 914 CV's, will pop first. (IMG:style_emoticons/default/confused24.gif) EDIT: Hey Mike, it doesn't have first gear and was not replaced during the rebuild. Presumably, the PO didn't want to spring for it or someone recommended not having it w/ the V8. I have the gears to replace it. What's your opinion on installing a 1st gear? |
Dr Evil |
Nov 15 2017, 12:00 PM
It should be OK. It came from one of your east coast rebuild clinic's and has the "H" gear. I don't plan on stomping on it off the line. Hopefully one of the fuses, aka 914 CV's, will pop first. (IMG:style_emoticons/default/confused24.gif) EDIT: Hey Mike, it doesn't have first gear and was not replaced during the rebuild. Presumably, the PO didn't want to spring for it or someone recommended not having it w/ the V8. I have the gears to replace it. What's your opinion on installing a 1st gear? Absolutely useless with your low end tq. If that person followed my advice (and it sounds like they did) then gearing will be F/O/X/flipped H. Its the safest, most liked, and most useful for high torque engines. Torque is the killer on these boxes so that is why the V8 can be risky. If driven with limitations in mind, it can last a long time. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:03 PM |
