Do CDI boxes require a coil? |
Aaron Cox |
Nov 5 2004, 04:42 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
buying a mallory unilite distributor, and hyfire CDI box. does this require a new coil? no coil? blue coil?
also- my webers have vaccuum ports on them. should i go with vac advance or not on the mllory |
SLITS |
Nov 6 2004, 01:20 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
One thing I forgot to add was that generally to feed a coil, you drop the voltage to 9V with a ballast resistor. If you don't, you'll get a REALLY hot spark that will take out the contacts in the dizzy cap quickly (read eventual missfire).
The Bosch "Blue" has a built in resistor. If you change to another "hot" coil, read the instructions carefully for it's use. Over and out! |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:53 AM |
