> Camshaft Confusion, Correct Part# to run original D-Jet
914_7T3
post Nov 15 2017, 12:02 PM
The cam from my '73 is worn and I have secured what I believe to be a NOS replacement part #021109111B that has been separated from its box (will arrive Monday). This is the identical part # to the one that was in my GA case and I purchased it listed as the correct part for my car along with the '76 912e.
However this is merely the part number for the Camshaft gear and there are no additional part #s on the Cam itself.
Questions as follows:
#1: The cam gear is riveted to the shaft as a one piece assembly, so is there anyway that this can be the incorrect replacement shaft?
#2 Cam Gear Part number 021109111C has a corresponding part #021109101K stamped on the cam itself. Some say that the difference is that the C designation is a stronger alloy versus magnesium for the part designation ending in B. Is that correct and would this be the correct cam as well for a GA case? If so, would you go alloy or magnesium? Both gears are marked -3 at the teeth.
#3 Worst case scenario, can the original be reground or would it be foolish to reuse.
#4 Are there any replacement Cams that are as good as or better than the NOS 44 year old OEM option?
Here are some pics as oily engine parts are cool (IMG:style_emoticons/default/sunglasses.gif)
Attached ImageAttached Image
Dr Evil
post Nov 17 2017, 02:23 PM
Send me your transmission!
From the Porsche PET catalog on line, here are the cam P/N.
914_7T3
post Nov 17 2017, 03:15 PM
QUOTE(Dr Evil @ Nov 17 2017, 12:23 PM) *
Thanks, I need the NLA 015M with a -3.
Problem is it’s a VW part with the VW part # stamped onto the cam. The Porsche part # is for reference only so hard to find, but I think I have a line on a few them in the VW world. Will know more next week.
Mark Henry
post Nov 17 2017, 04:44 PM
that's what I do!
QUOTE(914 7T3 @ Nov 17 2017, 04:15 PM) *
The part number will be a VW number even on a Porsche. The early 911, 356 and 914 are peppered with some VW small parts, they start with 111 or 113 or 021, 049, 411 xxx xxx which are all VW part prefixes.
914 prefix is 914 only, 901 and 911 are obviously 911. You also find all these prefixes on the 914.
Back in the day Porsche was a small company with little bulk buying power and it's rich cousin (VW) would let them raid their cookie jar. The T4 engine is pure VW till you hit the 2.0.
914 2.0 heads, crank, rods and bearings (designed by Porsche) start with 039 xxx xxx, not sure why they picked that number, but later 2.0 bus the rod and crank are 039 as well because it was on a 914 before a bus.
cornfused yet? how aboot the transmission it's a 914, but it's full of 901 parts (IMG:style_emoticons/default/wink.gif)
914 7T3   Camshaft Confusion   Nov 15 2017, 12:02 PM
914Sixer   Use the NOS cam you have and forget the rest.   Nov 15 2017, 12:09 PM
Mark Henry   Pretty sure the cam with green paint is a hydrauli...   Nov 16 2017, 12:58 PM
Mark Henry   Just checked, 2 rings, center of cam, 1 each side ...   Nov 16 2017, 01:06 PM
914 7T3   Just checked, 2 rings, center of cam, 1 each side...   Nov 16 2017, 05:20 PM
914Sixer   My bad, I did not know that the bands had anything...   Nov 16 2017, 03:30 PM
Mark Henry   One ring, bus FI 75- up, solid lifter, I don't...   Nov 16 2017, 06:06 PM
914 7T3   One ring, bus FI 75- up, I don't know how tha...   Nov 16 2017, 06:09 PM
Mark Henry   [quote name='Mark Henry' post='2549099' date='Nov...   Nov 16 2017, 06:18 PM
Mark Henry   021 xxx xxx is a VW bus prefix.   Nov 16 2017, 06:07 PM
914 7T3   021 xxx xxx is a VW bus prefix. 021 prefix is ...   Nov 16 2017, 06:23 PM
Mark Henry   I added the solid lifter to the info. Also is the ...   Nov 16 2017, 06:12 PM
914 7T3   Also is the ring a full ring or half ring? Ca...   Nov 16 2017, 06:25 PM
porschetub   Looks like your stock cam re-hardfaced and lifted ...   Nov 16 2017, 06:20 PM
Mark Henry   Cams are marked from +5 to -5, as tooling wore VW ...   Nov 16 2017, 07:03 PM
Dr Evil   From the Porsche PET catalog on line, here are the...   Nov 17 2017, 02:23 PM
914 7T3   From the Porsche PET catalog on line, here are th...   Nov 17 2017, 03:15 PM
Mark Henry   From the Porsche PET catalog on line, here are t...   Nov 17 2017, 04:44 PM
914 7T3   :agree: Thus the name of the thread “Camshaft ...   Nov 17 2017, 05:07 PM
Mark Henry   Oh and the trans case has VW and audi symbols on i...   Nov 17 2017, 05:14 PM
914Sixer   Elgin did my camshaft for my 2056. Using 330-1 imp...   Nov 17 2017, 05:50 PM
914 7T3   Elgin did my camshaft for my 2056. Using 330-1 im...   Nov 17 2017, 08:07 PM
914Sixer   That is Elgin's number for the cam grind. I s...   Nov 18 2017, 07:39 AM
Edward Blume   That is Elgin's number for the cam grind. I ...   Nov 19 2017, 08:32 AM
914Sixer   I talked Dema and he said it should be a good matc...   Nov 19 2017, 09:07 AM
914 7T3   Mark/Edward, That is encouraging, I have located ...   Nov 20 2017, 11:12 AM
Superhawk996   Follow up - New Learning So after having bought ...   Jun 10 2019, 07:06 PM
- Lo-Fi Version Time is now: 19th November 2026 - 10:45 AM
