| 914_7T3 |
Nov 15 2017, 12:02 PM
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,904 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California
The cam from my '73 is worn and I have secured what I believe to be a NOS replacement part #021109111B that has been separated from its box (will arrive Monday). This is the identical part # to the one that was in my GA case and I purchased it listed as the correct part for my car along with the '76 912e.
However this is merely the part number for the Camshaft gear and there are no additional part #s on the Cam itself. Questions as follows: #1: The cam gear is riveted to the shaft as a one piece assembly, so is there anyway that this can be the incorrect replacement shaft? #2 Cam Gear Part number 021109111C has a corresponding part #021109101K stamped on the cam itself. Some say that the difference is that the C designation is a stronger alloy versus magnesium for the part designation ending in B. Is that correct and would this be the correct cam as well for a GA case? If so, would you go alloy or magnesium? Both gears are marked -3 at the teeth. #3 Worst case scenario, can the original be reground or would it be foolish to reuse. #4 Are there any replacement Cams that are as good as or better than the NOS 44 year old OEM option? Here are some pics as oily engine parts are cool (IMG:style_emoticons/default/sunglasses.gif) ![]() ![]() ![]() ![]() |
| 914_7T3 |
Nov 17 2017, 05:07 PM
914 7T3 Camshaft Confusion Nov 15 2017, 12:02 PM
914Sixer Use the NOS cam you have and forget the rest. Nov 15 2017, 12:09 PM
Mark Henry Pretty sure the cam with green paint is a hydrauli... Nov 16 2017, 12:58 PM
Mark Henry Just checked, 2 rings, center of cam, 1 each side ... Nov 16 2017, 01:06 PM
914 7T3
Just checked, 2 rings, center of cam, 1 each side... Nov 16 2017, 05:20 PM
914Sixer My bad, I did not know that the bands had anything... Nov 16 2017, 03:30 PM
Mark Henry One ring, bus FI 75- up, solid lifter, I don't... Nov 16 2017, 06:06 PM
914 7T3
One ring, bus FI 75- up, I don't know how tha... Nov 16 2017, 06:09 PM
Mark Henry
[quote name='Mark Henry' post='2549099' date='Nov... Nov 16 2017, 06:18 PM
Mark Henry 021 xxx xxx is a VW bus prefix. Nov 16 2017, 06:07 PM
914 7T3
021 prefix is ... Nov 16 2017, 06:23 PM
Mark Henry I added the solid lifter to the info.
Also is the ... Nov 16 2017, 06:12 PM
914 7T3
Also is the ring a full ring or half ring?
Ca... Nov 16 2017, 06:25 PM
porschetub Looks like your stock cam re-hardfaced and lifted ... Nov 16 2017, 06:20 PM
Mark Henry Cams are marked from +5 to -5, as tooling wore VW ... Nov 16 2017, 07:03 PM
Dr Evil From the Porsche PET catalog on line, here are the... Nov 17 2017, 02:23 PM
914 7T3
From the Porsche PET catalog on line, here are th... Nov 17 2017, 03:15 PM
Mark Henry
From the Porsche PET catalog on line, here are t... Nov 17 2017, 04:44 PM
Mark Henry Oh and the trans case has VW and audi symbols on i... Nov 17 2017, 05:14 PM
914Sixer Elgin did my camshaft for my 2056. Using 330-1 imp... Nov 17 2017, 05:50 PM
914 7T3
Elgin did my camshaft for my 2056. Using 330-1 im... Nov 17 2017, 08:07 PM
914Sixer That is Elgin's number for the cam grind. I s... Nov 18 2017, 07:39 AM
Edward Blume
That is Elgin's number for the cam grind. I ... Nov 19 2017, 08:32 AM
914Sixer I talked Dema and he said it should be a good matc... Nov 19 2017, 09:07 AM
914 7T3 Mark/Edward,
That is encouraging, I have located ... Nov 20 2017, 11:12 AM
Superhawk996 Follow up - New Learning
So after having bought ... Jun 10 2019, 07:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th November 2026 - 10:45 AM |
