> OT: Airliner air conditioning, I know someone here will know this...
URY914
post Nov 5 2004, 02:17 PM
On a car the a/c compressor runs off the engine.
In a house the a/c compressor is run by an electric motor.
(you can figure out my next question, can't you?)
How is the compressor on a airliner (737, 747,etc) powered?
I've never noticed a big v-belt on the engine before.
If it is powered by a electric motor, if so how is the generator powered? Is there some type of power take off from jet engines?
Thanks,
Paul
URY914
post Nov 6 2004, 05:43 AM
QUOTE(Elliot Cannon @ Nov 5 2004, 09:48 PM)
QUOTE(URY914 @ Nov 5 2004, 08:05 PM)
Why couldn't  this be a easy answer?
I thought the question was easy.
How in the hell am I going to explain this to a 3rd grader?
Thanks guys,
Paul (IMG:style_emoticons/default/huh.gif)
The air comes out the side of the jet motor and is really hot. Then it goes through a machine that makes it a little bit cooler by using the wind that the airplane flies through. Then the air goes through another machine that squeezes it really tight and then lets it go real fast and when it comes out of the second machine the air is really cold. Then there is a mixing machine that mixes the really cold air with the really hot air and that machine can make the air any temperature you want it to be. That oughta confuse the little bugger. Good luck.
Cheers, Elliot
Thanks Elliot,
Thats a little better. (IMG:style_emoticons/default/wacko.gif)
URY914   OT: Airliner air conditioning   Nov 5 2004, 02:17 PM
Cano   It is my understanding, from watching something on...   Nov 5 2004, 02:21 PM
itsa914   I thought the pilot just opened a window :blink: ...   Nov 5 2004, 02:26 PM
Headrage   Engine bypass air.   Nov 5 2004, 02:27 PM
URY914   <...   Nov 5 2004, 02:29 PM
Headrage   On all the planes I worked on, they had ducting th...   Nov 5 2004, 02:35 PM
SLITS   Also, consider the temp of the intake air at altit...   Nov 5 2004, 02:37 PM
URY914   So the turbine would only be spinning with enough ...   Nov 5 2004, 02:38 PM
2-OH!   On the ground, air is bled off the APU (auxillary ...   Nov 5 2004, 02:45 PM
Kerrys914   Well in flight. How about no compressor at all :o ...   Nov 5 2004, 02:45 PM
maf914   ...   Nov 5 2004, 03:39 PM
redshift   lol m   Nov 5 2004, 03:48 PM
spare time toys   It takes air off the compressor section. Dependin...   Nov 5 2004, 03:50 PM
SLITS   And if you board a plane in Norfolk, VA in the sum...   Nov 5 2004, 04:00 PM
J P Stein   The new CF 7E7 is gonna eliminate bleed air ducti...   Nov 5 2004, 04:00 PM
spare time toys   ...   Nov 5 2004, 04:11 PM
Elliot Cannon   Bleed air ain't free. Cheers, Elliot   Nov 5 2004, 05:37 PM
Dominic     Nov 5 2004, 11:48 PM
URY914
- Lo-Fi Version Time is now: 3rd July 2025 - 04:05 PM
