Do CDI boxes require a coil? |
Aaron Cox |
Nov 5 2004, 04:42 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
buying a mallory unilite distributor, and hyfire CDI box. does this require a new coil? no coil? blue coil?
also- my webers have vaccuum ports on them. should i go with vac advance or not on the mllory |
Mueller |
Nov 6 2004, 10:30 AM
QUOTE(acox914 @ Nov 5 2004, 05:38 PM) QUOTE(SLITS @ Nov 5 2004, 05:29 PM) And you're an aspiring engineer? not electrical.... now ron, in all youre mighty knowledge of porsches...... tell me por favor Do not use that as an excuse!!!!! J Electrical or mechanical, does not matter, research and more research on the subject is critical, just looking for a simple yes or no answer is not acceptable, nor will you learn anything from it... also, do not focus on only "mechanical", there will be many times that knowing basics of electrical will be very, very helpful or downright necessary…it’ll help put you at the top of your class/field…….. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:31 PM |
