Electrical Question #15 Need Help Please, I'm totally stumped this time |
76-914 |
Apr 6 2014, 06:33 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm going to have several electrical questions. 1st, Is pin #8, on the 14 pin plug at the relay board, the only switched 12v+ source in the engine compartment? TIA, Kent
76-914 |
Nov 23 2017, 10:25 AM
Thanks for answering. Electrical issues remind me of how little I know. The blue wire enters as pin #2 on the 14 pin connector which goes to D+ and exits the relay board as a red wire presumably part of the alt harness. I wondered if I should ignore the blue lead or does it need to be connected to complete some ubiquitous circuit I'm unaware of. I do know the single lead goes to the battery but that's about all. (IMG:style_emoticons/default/lol-2.gif)
And now another issue. Last night I powered up the 2 main circuits which go to the fuse #11 & #27 steering column. One thing has me baffled. At first the turn signals worked all around. In fact all of the lights work including the pop up headlights. I noticed I had crossed a back up lite with a tail lite and corrected that. A few minutes later I was going thru the various components again and noticed the turn signals weren't working. No illumination at front or rear bulbs when the stalk was moved L&R. No flashing either. The PARK feature does work for the L & R sides and the flasher unit #47 works when the Hazard switch is pulled. (IMG:style_emoticons/default/confused24.gif) So this new question is twofold. Does the power go thru the flasher switch and/or turn signal assm first and then to the flasher unit OR the flasher unit first? 2nd; can the flasher unit work on the Hazard switch but not the turn signal? If I need to test the turn signal assm is there a procedure to follow? TIA, Kent |
Lo-Fi Version | Time is now: 10th June 2024 - 12:50 PM |
