my first porsche, is it worth it? |
440gordy |
Nov 26 2017, 05:41 PM
Newbie Group: Members Posts: 11 Joined: 26-November 17 From: washington state Member No.: 21,638 Region Association: Pacific Northwest |
I am about to buy this 914. it has a little rust but nothing i cant handle. Both the lower rocker tins are rusted out and there is a spot on the threshold where the rocker meets the door striker panel. Needs a battery tray and maybe bracket. some surface rust along the back trunk but should clean up easily. no rust in the front compartment. It is supposed to have a slipping clutch, probably oil soaked from a leak. all in all a really straight car. I did get it started for about 30 seconds by bypassing the fuel pump and using another pump and running fuel direct from a gas can and it sounded just fine. It appears to have 106k. if i purchase this i plan to tear it to the ground and repaint it completely. and make any needed repairs. I don't want to overpay for it and then be buried in it. From what i have stated can any of you give me a good starting purchase price and possible end value. any knowledge form you guys would be greatly appreciated!! |
injunmort |
Nov 26 2017, 07:51 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
fwiw, i am no longer a fan of the "buy a good west roller mentality". i have repaired worse. if you have the courage to undertake a resto, go for it, at $850.00 you wont get hurt even if you abandon it.they are worth restoring for their driving pleasure alone. non rusted survivors are few and far between, these are not for the feighnt of heart but are worth the effort
440gordy |
Nov 26 2017, 08:51 PM
fwiw, i am no longer a fan of the "buy a good west roller mentality". i have repaired worse. if you have the courage to undertake a resto, go for it, at $850.00 you wont get hurt even if you abandon it.they are worth restoring for their driving pleasure alone. non rusted survivors are few and far between, these are not for the feighnt of heart but are worth the effort i feel no matter what it will be fun get running and drive. I feel confident since i have a lot of body experiance. i used to do Rebuilds and have learned how to properly remove sheet metal and if need be make the piece if needed. plus i know body work and i can lay down the paint. even if it has a couple our of sight rust spots its going to be a heck of a good looking car when i'm done with it! |
Lo-Fi Version | Time is now: 1st June 2024 - 07:46 AM |
