911s motor @ SMC ?, seems ok but... |
porschetub |
Nov 26 2017, 07:42 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Got a black Friday special from them this motor included,no real rebuild history 300 miles since rebuild ,increased compression and numbers supplied which really if a rebuilt motor would be a little off the game for only 300 miles (15+%).
Factor in 2.7 issues and it sounds like a cheap build @13.5 K even its a complete motor,things that come to mind; Case clean ,measuring and possible line bore and resize, bearings gaskets, chains and ramps, pistons and barrels...can of worms costwise, head studs which would need replacing, crank ? measured ,polished/reground and cleaned, heads,cleaned,flycut ,new guides,exhaust valves @ minimum, rocker arms,cleaning measuring,rebushing if needed, oil pump stripped and inspected, parts for injection system,injectors tested,fuel distributor etc, plus altenator rebuild,clean ,paint engine tin and shroud, new exhaust fitted, then sh#t loads of labour to box it up, etc etc. Numbers don't work for me if all the correct work has been done (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) ,need this for possible purchase of a 2.7 which I don't really need (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) . Anyone rebuild a 2.7 and can confirm numbers for a rebuild to a similar motor / TIA. |
mepstein |
Nov 26 2017, 08:00 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Cost the same to rebuild a 2.7, 3.0 or 3.2.
I would rather have the two later ones. |
sithot |
Nov 26 2017, 08:56 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Cost the same to rebuild a 2.7, 3.0 or 3.2. I would rather have the two later ones. (IMG:style_emoticons/default/agree.gif) 3.0 or 3.2. A "good" 2.7 is ok but it requires more work. Case Savers or Time Serts if the engine suffered "pulled" studs. The really hot running Thermal Reactor '75-'77 cars were notorious. Line boring should definitely be considered. The 3.0 and 3.2 will eventually break studs. Last two SC's I owned required all the studs to be replaced. Breakage isn't uncommon and I for one would budget for a top end rebuild when purchasing either engine. FWIW: The SC rod bolts are larger so it's a bit more hearty. That's something that could be addressed with a full rebuild but either car should last a long time on the stock bottom end unless you're beating it like a rented mule. The 3.6's cooked their exhaust valve guides due to the engine tray (for sound abatement) which as best I can tell was better at keeping oil off the floor because it sure as heck didn't dissipate heat. I'm not a big horsepower person. A really sweet high strung 2.0 or 2.2 would be fine. It's all about balance. Gearboxes are another place to find hidden "horsepower". Stacked gear sets/close ratio/airport etc. are a lot of fun and if done right can keep the engine in the "sweet spot". |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:05 PM |
