swood |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None ![]() |
Ok, I've finally cut the p-rods and am loading them in and adjusting the valves. Right now it's on TDC for #1. I notice that when I turn the flywheel, at some point in the rotation there is a little tightness for a few degrees, maybe a 1/4 turn or so. My jugs were opened to 96mm with new KB's and hastings rings. Could this be just the rings on one of the pistons when down low in the cylinder? I don't know how free a new motor is to turn. The crank turned smooth as silk before connecting the rods, p&c's etc.
My hands hurt from the teeth on the flywheel so any thoughts would be great. |
Zeke |
Never left, but not right.... ![]() ![]() Group: Members Posts: 382 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None ![]() |
There is a point when all 4 pistons are in mid stroke twice in each revolution. The drag of the new rings on the freshly honed cyls creates a pretty good resistance.
If it is doing this right after TDC and BDC on no. 1, it's normal. Did you assemble the P/C's dry like a lot of engine builders say to do? Aids in breaking in the rings. (of course, you shouldn't take advice from a guy who broke 2 motors in less than 5 laps at Willow Springs) (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 15th June 2024 - 07:09 PM |
