911s motor @ SMC ?, seems ok but... |
porschetub |
Nov 26 2017, 07:42 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Got a black Friday special from them this motor included,no real rebuild history 300 miles since rebuild ,increased compression and numbers supplied which really if a rebuilt motor would be a little off the game for only 300 miles (15+%).
Factor in 2.7 issues and it sounds like a cheap build @13.5 K even its a complete motor,things that come to mind; Case clean ,measuring and possible line bore and resize, bearings gaskets, chains and ramps, pistons and barrels...can of worms costwise, head studs which would need replacing, crank ? measured ,polished/reground and cleaned, heads,cleaned,flycut ,new guides,exhaust valves @ minimum, rocker arms,cleaning measuring,rebushing if needed, oil pump stripped and inspected, parts for injection system,injectors tested,fuel distributor etc, plus altenator rebuild,clean ,paint engine tin and shroud, new exhaust fitted, then sh#t loads of labour to box it up, etc etc. Numbers don't work for me if all the correct work has been done (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) ,need this for possible purchase of a 2.7 which I don't really need (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) . Anyone rebuild a 2.7 and can confirm numbers for a rebuild to a similar motor / TIA. |
porschetub |
Dec 1 2017, 05:56 PM
Thanks for the replies,sounds like a can of worms, the local seller I'am dealing with says ROW Japanese motor with work done,just over 100k kilometers on it documented but finally he comes clean and tells me its had headstuds replaced on one side only.... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) .
Run Forrest run (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/wacko.gif) . |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:28 PM |
