torque setting calculations |
JFG |
Dec 2 2017, 02:39 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I've discovered that my torque wrench only goes up to 160 ft lbs. I need another 50 ft lbs to lock up the rear drive shafts into the wheel bearing hub.
I have an angle gauge and was wondering if it is possible to convert the remaining 50 ft lbs into degrees for the angle gauge? |
Elliot Cannon |
Dec 2 2017, 12:04 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Buying a torque wrench from HF. Standing on a breaker bar. Pretty much the same accuracy. (IMG:style_emoticons/default/av-943.gif)
stugray |
Dec 2 2017, 01:45 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Buying a torque wrench from HF. Standing on a breaker bar. Pretty much the same accuracy. (IMG:style_emoticons/default/av-943.gif) Actually the "standing on the breaker bar" is perfectly accurate (assuming you do the calc correctly), but only as good as your bathroom scale. |
Elliot Cannon |
Dec 2 2017, 10:28 PM
Buying a torque wrench from HF. Standing on a breaker bar. Pretty much the same accuracy. (IMG:style_emoticons/default/av-943.gif) Actually the "standing on the breaker bar" is perfectly accurate (assuming you do the calc correctly), but only as good as your bathroom scale. So, if you attached one of these to a 2 foot long breaker bar and pulled till it read 125 lbs. would that equal 250 foot lbs.? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 22nd May 2024 - 09:18 PM |
