Heat Control Flapper Valves, Are the valves on each side the same? |
db9146 |
Dec 3 2017, 07:05 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Got a question on the heater control flapper valves on a -6. On mine, the driver side flapper has a solid cap over one side of the flapper valve while the passenger side flapper valve has a hole about 1.5" in diameter in the cap.
Anyone know the a reason for the one having a hole? |
mepstein |
Dec 4 2017, 09:30 AM
914-6 GT in waiting Group: Members Posts: 19,300 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Rory - if I drilled a 1 1/2” hole in the top of my (four) valves, would it duplicate the sixes in function? Or is their an internal difference.
rgalla9146 |
Dec 4 2017, 11:17 AM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Rory - if I drilled a 1 1/2” hole in the top of my (four) valves, would it duplicate the sixes in function? Or is their an internal difference. Hey Mark The differences I noted are visible from the outside. I believe they function exactly the same. A 4cyl. part with a hole in the cover should be fine. The function of different diameter caps ? Dump capacity ? |
mepstein |
Dec 4 2017, 11:30 AM
Rory - if I drilled a 1 1/2” hole in the top of my (four) valves, would it duplicate the sixes in function? Or is their an internal difference. Hey Mark The differences I noted are visible from the outside. I believe they function exactly the same. A 4cyl. part with a hole in the cover should be fine. The function of different diameter caps ? Dump capacity ? I'll buy that. The 6 fans move a lot of air. Thanks! |
Lo-Fi Version | Time is now: 29th May 2024 - 06:06 AM |
