Motor is tight when turning by hand |
swood |
Nov 6 2004, 10:14 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, I've finally cut the p-rods and am loading them in and adjusting the valves. Right now it's on TDC for #1. I notice that when I turn the flywheel, at some point in the rotation there is a little tightness for a few degrees, maybe a 1/4 turn or so. My jugs were opened to 96mm with new KB's and hastings rings. Could this be just the rings on one of the pistons when down low in the cylinder? I don't know how free a new motor is to turn. The crank turned smooth as silk before connecting the rods, p&c's etc.
My hands hurt from the teeth on the flywheel so any thoughts would be great. |
Demick |
Nov 7 2004, 12:28 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
QUOTE(swood @ Nov 7 2004, 09:52 AM) T1 oil pump (clearanced) Shaedek.. Web cam 73 grind and new Web cam gear. Jake does say that clearance is very close when the T1 oil pump is used. Still - if this was the problem, I think you would have caught it earlier. I'm sure that you probably rotated the engine by hand after the oil pump was installed and before the P&C's were installed. Demick |
Lo-Fi Version | Time is now: 15th June 2024 - 02:26 PM |
